Serial Communication not working
Hallo! I’m currently writing a big lab in university. Serial communication is just a part of a my project. The thing is, I have to do my task in ASM. But I’m still using Arduino as a board. I wrote a code (added it to a message). It has basic things to work with USART-interface. Based on interrupts. I debugged code and tested it with virtual Atmega 1280 (the one installed on my Arduino Mega) and virtual terminal in Proteus. And serial transmission also worked great.
But when I uploaded project to my Arduino and connected it via a virtual com (the one that maps a real one) and terminal in Proteus, I received absolutely nothing! No output to a virtual terminal.
The lights near FTDI that usually tell about RX-TX, don’t give any output also.
What might be a reason of it? I had some suspicions connected with ftdi. I connect my Arduino to PC via usb that is recognized like a virtual com-port. Can it be possible that USART output(I use USART0) somehow goes to pins marked like 0 and 1 and doesn’t go through ftdi to the actual port I’m using?
Thank you, I appreciate any answer and help of yours!
Code. Don’t mind mess with timer, it’s okay.
 .include "m1280def.inc"   ;
;-------DATASEGMENT------------------------------------
.dseg
b: .byte 0xEE
;-------CODESEGMENT:Interuption Vector Table ----------
.cseg
.ORG 0
rjmp MAIN
.ORG $0022
rjmp timerMatchA  ; Timer matches A number
.ORG $0032
rjmp receiveInt   ; Byte received
.ORG $0034
rjmp emptyInt	  ; Shift buffer is empty
.ORG $0036
rjmp transmitInt  ; Byte transmitted
.ORG   INT_VECTORS_SIZE
;-------CODESEGMENT:Interuption Handler ---------------
timerMatchA:
;	push r16
;	push r17
;	in r17, SREG
;	ldi r16, 0
;	out TCCR1B, r16
;	ldi r16, 1<<RXEN|1<<TXEN|1<<RXCIE|1<<TXCIE|1<<UDRIE
;	out UCSRB, r16
;	ldi r16, 0
;	out TCNT1H, r16
;	out TCNT1L, r16
;	out SREG, r17
;	pop r17
;	pop r16
	reti
receiveInt:
	reti
emptyInt:
	push r16
	push r17
	in r17, SREG
	brts load1
	rcall loadSensor2
	rjmp sendByte
load1:
	rcall loadSensor1
sendByte:
	sts UDR0, r16
	ldi r16, 1<<RXEN0|0<<TXEN0|1<<RXCIE0|0<<TXCIE0|0<<UDRIE0
	sts UCSR0B, r16
	out SREG, r17
	pop r17
	pop r16
	reti
transmitInt:
	reti
loadSensor1:
	mov r16, r18
	ret
loadSensor2:
	mov r16, r19
	ret
;--------CODESEGMENT:CONSTANTS-------------------------
.equ XTAL = 8000000
.equ BAUD = 9600
.equ NUM = XTAL/(16*BAUD) - 1
.equ TimerMaxValue = 1000/140
;--------CODESEGMENT:CODE------------------------------
UpdateSensor1:
	inc r18
	ldi r18, 0x42
	ret
UpdateSensor2:
	ldi r19, 0x43
	inc r19
	ret
MAIN:
	cli
	ldi r16, low(RAMEND)
	out SPL, r16
	ldi r16, high(RAMEND)
	out SPH, r16
	ldi r16, 0
	sts TCNT1H, r16
	sts TCNT1L, r16
	ldi r16, high(TimerMaxValue)
	sts OCR1AH, r16
	ldi r16, low(TimerMaxValue)
	sts OCR1AL, r16
	ldi r16, 0
	sts TCCR1A, r16
	ldi r16, 0
	sts TIMSK1, r16
; Setting baud rate
	ldi r16, low(NUM)
	sts UBRR0L, r16
	ldi r16, high(NUM)
	sts UBRR0H, r16
; /Setting baud ratw
; Initial inicialization of TX-RX values
	ldi r16, 0
	sts UCSR0A, r16
; /Initial inicialization of TX-RX values
; Standard packet size
	ldi r16, 1<<UCSZ00|1<<UCSZ01
	sts UCSR0C, r16
; /Standard packet size
; TX enabled, RX enabled, interrupts on end of RX and TX enabled.
	ldi r16, 1<<RXEN0|1<<TXEN0|1<<RXCIE0|1<<TXCIE0|0<<UDRIE0
	sts UCSR0B, r16
; /TX enabled, RX enabled, interrupts on end of RX and TX enabled.
	sei
	ldi r16, 0b11110000
	mov r15, r16
	next:
		ldi r16, 1<<WGM12|1<<CS12|0<<CS11|1<<CS10
		sts TCCR1B, r16
		lds r19, TCCR1b
		;wait1:
			in r16, TIFR1
			sbrs r16, OCF1A
		;	jmp wait1
		bst r15, 7
		rcall UpdateSensor1
		ldi r16, 0
		sts TCCR1B, r16
		sts TCNT1H, r16
		sts TCNT1L, r16
		ldi r16, 1<<RXEN0|1<<TXEN0|1<<RXCIE0|1<<TXCIE0|1<<UDRIE0
		sts UCSR0B, r16
		ldi r16, 0xFF
		out TIFR1, r16
		sts TCCR1B, r16
		lds r16, OCR1AL
		;wait2:
			in r16, TIFR1
			sbrs r16, OCF1A
		;	jmp wait2
		bst r15, 0
		rcall UpdateSensor2
		ldi r16, 0
		sts TCCR1B, r16
		sts TCNT1H, r16
		sts TCNT1L, r16
		sts UCSR0B, r16
		ldi r16, 0xFF
		out TIFR1, r16
	rjmp next
;--------EEPROMSEGMENT---------------------------------
.eseg
Why?
Character building.
I'm serious, guys. Need help.
Bardos: I'm serious, guys. Need help.
Since you aren't using the Arduino Libraries and you are programming in ASM, you probably need to ask in AVR Freaks or similar forums.
Why are you using ASM?
Well, because it was a task given by a teacher.
