Serial Communication PC CPU Load?.. I2C or Serial?
I have a setup involving a few Arduino mega boards. I can communicate with all of them using a usb hub (successfully), but I was worried about the load on my laptop.
Does anyone have any idea about about how resource intensive serial communication is on a laptop (dual core windows 7) at about 100kbps?
I was thinking that instead of having multiple serial connections to each of the Arduino mega boards, I would have less connections (but the same amount of data), and use I2C between the Arduinos.
Does this make any sense?
Your thoughts appreciated
Chendy
The hardware side on the laptop is all USB, so it is not very resource-intensive at all. (however, the application can be more or less efficient in getting the data from USB through the virtual serial port to the app. Reading one byte at a time on multiple ports running at 100kbps is probably not a great idea, and being more efficient may not be intuitively "easy.")
In the end, you should benchmark your particular application (or a model of it.)
