serial communication problem
hello all! I have an arduino uno, and have been using it to sync Christmas lights to music using serial communication. I built a box with transistors and relays and many other components. it worked great for the first three nights, but on the fourth night I encountered a problem.
The problem was that the arduino was not outputing the correct outputs, and the lights got off of the music. The show was running fine for a few hours, but then all of a sudden it just got off. I am not great at programming, so im hoping someone may just find a stupid error in my coding.
I was just confused since it was working fine for hours, and then all of a sudden stopped working correctly.
here’s my code:
int Chan0 = 0;
int Chan1 = 1;
int Chan2 = 2;
int Chan3 = 3;
int Chan4 = 4;
int Chan5 = 5;
int Chan6 = 6;
int Chan7 = 7;
int Chan8 = 8;
int Chan9 = 9;
int Chan10 = 10;
int Chan11 = 11;
int Chan12 = 12;
int Chan13 = 13;
int i = 0;     // Loop counter
int incomingByte[14];   // store the 14 values from the serial port
  Serial.begin(9600);        // set up Serial at 9600 bps
  pinMode(Chan0, OUTPUT);   // pins as output
  pinMode(Chan1, OUTPUT);
  pinMode(Chan2, OUTPUT);
  pinMode(Chan3, OUTPUT);
  pinMode(Chan4, OUTPUT);
  pinMode(Chan5, OUTPUT);
  pinMode(Chan6, OUTPUT);
  pinMode(Chan7, OUTPUT);
  pinMode(Chan8, OUTPUT);
  pinMode(Chan9, OUTPUT);
  pinMode(Chan10, OUTPUT);
  pinMode(Chan11, OUTPUT);
  pinMode(Chan12, OUTPUT);
  pinMode(Chan13, OUTPUT);
{  // 14 channels coming to Arduino
   if (Serial.available() >= 14) {
    for (int i=0; i<15; i++) {
       incomingByte[i] = Serial.read();
    digitalWrite(Chan0, incomingByte[0]);
    digitalWrite(Chan1, incomingByte[1]);
    digitalWrite(Chan2, incomingByte[2]);
    digitalWrite(Chan3, incomingByte[3]);
    digitalWrite(Chan4, incomingByte[4]);
    digitalWrite(Chan5, incomingByte[5]);
    digitalWrite(Chan6, incomingByte[6]);
    digitalWrite(Chan7, incomingByte[7]);
    digitalWrite(Chan8, incomingByte[8]);
    digitalWrite(Chan9, incomingByte[9]);
    digitalWrite(Chan10, incomingByte[10]);
    digitalWrite(Chan11, incomingByte[11]);
    digitalWrite(Chan12, incomingByte[12]);
    digitalWrite(Chan13, incomingByte[13]);
I am using the software Vixen, and the output is generic serial. I just have no idea why it worked for hours, then stopped. Every night when i restart it, it will get off again so i stop the show and restart it.
any help would be greatly appreciated :slight_smile:
Two things…
  1. The maximum array index is 13 not 14. The array is too small…
incomingByte = Serial.read();
  • }[/font]*
    2. Your protocol has no synchronization. If any data is lost… well, you know the result.
int Chan0 = 0;
int Chan1 = 1;
int Chan2 = 2;
int Chan3 = 3;
int Chan4 = 4;
int Chan5 = 5;
int Chan6 = 6;
int Chan7 = 7;
int Chan8 = 8;
int Chan9 = 9;
int Chan10 = 10;
int Chan11 = 11;
int Chan12 = 12;
int Chan13 = 13;
I don't see the point of this. Each one is its name. (Chan4 is 4 and so on).
Better read up on the "for" loop. You could save a lot of coding here.
[quote author=Coding Badly link=topic=138729.msg1042017#msg1042017 date=1356236141] 2. Your protocol has no synchronization. If any data is lost... well, you know the result. [/quote]
Disaster?
[quote author=Nick Gammon link=topic=138729.msg1042066#msg1042066 date=1356243307]Disaster?[/quote]
For a Christmas display aficionado, you bet!
The symptom would be similar or identical to what @mennis22 described: lights and sound no longer synchronized.
No one else sees the problem with using pins 0 and 1 as output pins while reading serial data?
PaulS: No one else sees the problem with using pins 0 and 1 as output pins while reading serial data?
That, plus the lack of any method to detect and recover from errors on the serial stream.
(shameless self-promotion)
SerialCommands: easy command-based sketches
http://arduino.cc/forum/index.php/topic,133148.0.html
Thanks for the help everyone!! I believe it was in part of using pins 0 and 1. I don’t have them hooked up to anything but they were still in the code.
I’m sorry if this seemed like a dumb question. I’m only 17 and taught this all to myself so sorry for sounding stupid.
Hope everyone has a great Christmas!
mennis22:
The only way it would be a dumb question is if you were born with the knowledge of how to program an Arduino. I assume that is not the case which makes this nothing more than a learning experience.
Back at ya!
