Hi everyone, I really need your help ! Okay before I start here's my code below :
#include <SoftwareSerial.h> //add the soft serial libray
#define rxpin 2 //set the RX pin to pin 2
#define txpin 3 //set the TX pin to pin 3
SoftwareSerial myserial(rxpin, txpin); //enable the soft serial port
String inputstring = ""; //a string to hold incoming data from the PC
String sensorstring = ""; //a string to hold the data from the Atlas Scientific product
boolean input_stringcomplete = false; //have we received all the data from the PC
boolean sensor_stringcomplete = false; //have we received all the data from the Atlas Scientific product
void setup(){ //set up the hardware
Serial.begin(38400); //set baud rate for the hardware serial port to 38400
myserial.begin(38400); //set baud rate for software serial port to 38400
inputstring.reserve(5); //set aside some bytes for receiving data from the PC
sensorstring.reserve(30); //set aside some bytes for receiving data from Atlas Scientific product
void serialEvent() { //if the hardware serial port receives a char
char inchar = (char)Serial.read(); //get the char we just received
inputstring += inchar; //add it to the inputString
if(inchar == '\r') {input_stringcomplete = true;} //if the incoming character is a <CR>, set the flag
void loop(){ //here we go....
inputstring = "C\r"; // send command C to device and carriage return
if (input_stringcomplete){ //if a string from the PC has been recived in its entierty
myserial.print(inputstring); //send that string to the Atlas Scientific product
inputstring = ""; //clear the string:
input_stringcomplete = false; //reset the flage used to tell if we have recived a completed string from the PC
while (myserial.available()) { //while a char is holding in the serial buffer
char inchar = (char)myserial.read(); //get the new char
sensorstring += inchar; //add it to the sensorString
if (inchar == '\r') {sensor_stringcomplete = true;} //if the incoming character is a <CR>, set the flag
if (sensor_stringcomplete){ //if a string from the Atlas Scientific product has been received in its entirety
Serial.print(sensorstring); //use the hardware serial port to send that data to the PC
sensorstring = ""; //clear the string:
sensor_stringcomplete = false; //reset the flag used to tell if we have received a completed string from the Atlas Scientific product
The only way I can get it working is by writing at the serial monitor of arduino. I know it's not Serial Write since it only print in the serial monitor but not send in the command into the device.
I'm trying to send some character into the inputstring but no matter what I've done it doesn't apply why's that so? I also include a statement of sending a command letter C with a carriage return to the device and I've already set the same baud rate. If I get this going I want to implement into a push button or switch. So whenever I need it I would switch it on and whenever I don't need it I will switch it off.
