serial communication question
this is the easiest question you will answer today, i promise. I would jsut test it myself buuuut I may have made my arduino a biiiiit not worky worky.
if I try to write the value 400 to the serial port, what comes out the port? say for example
Serial.print(400); or Serial.write(400);
I know it compiles, but that is about it.
Serial.print(400) will send '4', '0', '0' to the serial port.
Serial.write(400) will send 144 to the serial port - the write() function takes a byte, so only the low order byte (containing 144) is sent. The high order byte is ignored.
