On ATtiny85 i am measuring voltage (up to 24V) with voltage divider and sending it through TX pin (PB3) to RX port of Arduino Nano every second. I saw idea about Tiny Debug Serial here -> Communication with Tiny's
I am sending received information about voltage to LCD screen, which is connected to Nano. I am using Serial.parseInt() on the RX side because i want to see real voltage value on LCD.
Everything works but from time to time (every few seconds but not constantly) i am seeing wrong readings on LCD screen. For example, i am measuring fixed voltage of 12V. Most of the time i see 12 on the LCD but every few seconds i am getting strange voltage readings like 1, 2, 9, etc, and than 12V again. I also tried with Serial.parseFloat(), to get more accurate numbers but the problem is even worse.
Probably, i've got problem in code, since this is my first serial communication project between two devices. I am running TX side (ATtiny) at 8 MHz and Nano with 16 MHz but this shouldn't be a problem if baudrate on both sides is set to 9600, right?
TX Attiny side
int voltage = 0;
int raw = analogRead(A2);
voltage = (raw / 1024.0) * 29;
Serial.println(voltage);
RX Nano side
int val;
lcd.begin(16,2);
lcd.clear();
if (Serial.available() > 0)
val = Serial.parseInt();
lcd.setCursor(0,0);
lcd.print("RX voltage:");
lcd.setCursor(0,1);
lcd.print(val);
if (val < 10) lcd.print(" ");
lcd.setCursor(0,0);
lcd.print("RX disconnected");
fungus:
Either that or SoftwareSerial is failing, again....
Is that a frequent problem with SoftwareSerial?
On the first look, the code (on both sides, RX and TX) is ok or i made any obvious mistake? I will try to add checksum but i don't know how to do it yet.
So for example, if code is ok and this SoftwareSerial is causing problems (on which i have no impact), and since that's the only way i can communicate with ATtiny over Serial communication.. I have got serious problem.
luxy:
But for example, what if i want to upgrade this "cable" connection with bluetooth later?
In theory you can tune the internal oscillator. All you do is send a message over the serial line and put values into the OSCCAL register until it works (see "System Clock and Clock Options" in the datasheet).
People have varying success rates though. For an accurate clock speed you really need an external crystal.
They're $3 each for a Mega328 on a PCB with 16MHz crystal. You get hardware interfaces for everything and most Arduino libraries are designed for Unos so they work with no modification.
At that price it's really not worth using anything else or even trying to build your own. They even come with header pins so you can fix them to a PCB easily.
Thank you for advice.. I think i will buy this because looks like a really good deal
I used to built standalone versions with ATmega8 because i have.. well, really a lot of this chips and mainly i don't need so much space for code.. For me 8kb is enough for most apps.
I will try serial RX/TX (not software serial) on pins 0/1 and with 16 MHz crystal. If this won't go, i will use I2C.
Try sending the data slower, lower baud rate , or leave a pause between the characters being sent.
Software Serial doesnt have a receive buffer, so data can get corrupted if data is coming in , but the CPU is doing something else
like writing to a display.
mauried:
Ok, i will try with lower baudrate (300 for example) but where do you think to put pause on TX side? I have got 1 second pause after every sending, if that's it?
