serial communication via NewSoftSerial library with sabertooth 2*5A motor driver
Hi Arduino folks,
I have a question regarding the NewSoftSerial library.
I have a sketch which should help me to communicate with my sabertooth Motor Driver over Serial:
#include
 int x, r, l, s, f, xa, xb, xc;
#include <NewSoftSerial.h>
//serieller transmitter
 #define SABER_TX_PIN  13
 //Serieller empfänger
 #define SABER_RX_PIN  12
 //baudrate zur übereinstimmung mit den dip einstellungen
 #define SABER_BAUDRATE  9600
NewSoftSerial SaberSerial = NewSoftSerial (SABER_RX_PIN, SABER_TX_PIN );
 void initSabertooth (void)  {
   //kommunikation mit sabertooth
 pinMode ( SABER_TX_PIN, OUTPUT );
 SaberSerial.begin( SABER_BAUDRATE );
   initSabertooth();
 void set_motor()   {
   x = analogRead(0);
 //x winkel ist  270-400 astabil bei 330
 xa = x;
 delay (20);
 x = analogRead(0);
 xb = x;
 delay (20);
 x = analogRead(0);
 xc = x;
 x= (xa +xb + xc)/3;
 //SABER_right_FULL_FORWARD 127
 //SABER_right_FULL_REVERSE 1
 //SABER_left_FULL_FORWARD 255
 //SABER_left_FULL_REVERSE 128
 s = 1.8  ;
 f = 5;
 //stabilitätspunkt bei 330
 if ((x > 325) && (x < 335)) {
 r = 62;
 l = 194;
 //leicht nach vorne 310 > x < 330
 if ((x > 310) && (x < 326)) {
 r = 45;
 l = 167;
 //schneller nach vorne 279 > x < 311
 if ((x > 279) && (x < 311)) {
 r = s * x - 278 + f;
 l = s * x - 148 + f;
 //stark nach vorne x < 280
 if ((x > 250) && (x < 280)) {
 r = 6;
 l = 133;
 // laicht nach hinten 334 > x > 349
 if ((x > 334) && (x < 349)) {
 r = 78;
 l = 208;
 //schneller nach hinten fallen 348 < x < 390
 if ((x > 348) && (x < 391)) {
 r = s * x - 270 + f;
 l = s * x - 140 + f;
 //stark nach hinten 390 < x
 if ((x > 390) && (x < 410)) {
 r = 122;
 l = 250;
 //zum sabertooth senden
 SaberSerial.write(byte(r));
 SaberSerial.write(byte(l));
 void loop ()  {
 float level = 0;
 int u;
   set_motor();
when trying to compile this I get the following error message:
NewSoftSerial does not Name a type
I think the error occurs because of this Statement, which I’m not able to fix:
Maybee it’s a thumb question but I really don’t get if I have to insert a type Definition an if so which…
Thanks in advance,
NearCZ
p.s Sorry for bad spelling(auto-correction)
and please excuse me for doing things wrong as this is my first post in the Forum… :~
