Hello everyone,
i'm new to the arduino and hope you can help me out with my project i trying to achieve.
my setup is the following:
LED Matrix 12x(8x8) + Arduino Uno + USB from PC/Mac
i included the MD_parola and MD_MAX72xx library and used their serial test example which comes within the installation.
Now further on to my question;
basically what i want to do is to send data via a python script to be displayed on the LED Matrix.
Python script:
import time
import serial
arduino = serial.Serial('/dev/cu.usbmodemFA121', 57600, timeout=.1) #serial connection
time.sleep(1)
newMessage = "Test Test Test"
arduino.write(newMessage)
arduino.close()
Arduino script:
// Use the Parola library to scroll text on the display
// Demonstrates the use of the scrolling function to display text received
// from the serial interface
// User can enter text on the serial monitor and this will display as a
// scrolling message on the display.
// Speed for the display is controlled by a pot on SPEED_IN analog in.
// Scrolling direction is controlled by a switch on DIRECTION_SET digital in.
// Invert ON/OFF is set by a switch on INVERT_SET digital in.
// UISwitch library can be found at https://github.com/MajicDesigns/MD_UISwitch
// MD_MAX72XX library can be found at https://github.com/MajicDesigns/MD_MAX72XX
#include <MD_Parola.h>
#include <MD_MAX72xx.h>
#include <SPI.h>
// set to 1 if we are implementing the user interface pot, switch, etc
#define USE_UI_CONTROL 0
#if USE_UI_CONTROL
#include <MD_UISwitch.h>
#endif
// Turn on debug statements to the serial output
#define DEBUG 0
#if DEBUG
#define PRINT(s, x) { Serial.print(F(s)); Serial.print(x); }
#define PRINTS(x) Serial.print(F(x))
#define PRINTX(x) Serial.println(x, HEX)
#else
#define PRINT(s, x)
#define PRINTS(x)
#define PRINTX(x)
#endif
// Define the number of devices we have in the chain and the hardware interface
// NOTE: These pin numbers will probably not work with your hardware and may
// need to be adapted
#define HARDWARE_TYPE MD_MAX72XX::FC16_HW
#define MAX_DEVICES 12
#define CLK_PIN 13
#define DATA_PIN 11
#define CS_PIN 10
// HARDWARE SPI
MD_Parola P = MD_Parola(HARDWARE_TYPE, CS_PIN, MAX_DEVICES);
// SOFTWARE SPI
//MD_Parola P = MD_Parola(HARDWARE_TYPE, DATA_PIN, CLK_PIN, CS_PIN, MAX_DEVICES);
uint8_t scrollSpeed = 25; // default frame delay value
textEffect_t scrollEffect = PA_SCROLL_LEFT;
textPosition_t scrollAlign = PA_LEFT;
uint16_t scrollPause = 2000; // in milliseconds
// Global message buffers shared by Serial and Scrolling functions
#define BUF_SIZE 75
char curMessage[BUF_SIZE] = { "" };
char newMessage[BUF_SIZE] = { "Newsticker Test" };
bool newMessageAvailable = true;
void readSerial(void)
static char *cp = newMessage;
while (Serial.available())
*cp = (char)Serial.read();
if ((*cp == '\n') || (cp - newMessage >= BUF_SIZE-2)) // end of message character or full buffer
*cp = '\0'; // end the string
// restart the index for next filling spree and flag we have a message waiting
cp = newMessage;
else // move char pointer to next position
cp++;
Serial.begin(57600);
Serial.print("\n[Parola Scrolling Display]\nType a message for the scrolling display\nEnd message line with a newline");
P.begin();
P.displayText(curMessage, scrollAlign, scrollSpeed, scrollPause, scrollEffect, scrollEffect);
if (P.displayAnimate())
if (newMessageAvailable)
strcpy(curMessage, newMessage);
newMessageAvailable = false;
P.displayReset();
readSerial();
If i open the serial monitor i can write a word and it is displayed on the LED Matrix..why can't i achieve this with a python script?
Do i have a main understanding issue here.
I really hope you guys can help me out on this one.
Sorry for my bad english.
Thank you for your help, great community!
