I am tring to realize communication with a self-defined protocol device using serial port. The frame length is not fixed but the terminator is fixed. So i want to use the readBytesUntil(char terminator, char *buffer, size_t length) function to get the frame which i want.
However, the terminator in the self-defined protocol is a 2 bytes terminator which is 0x0D0A, and the parameter char terminator is 1 byte. So how can i realize the fixed 2 bytes terminator communication?
And more :what is the better choice when i meet some problem like this?(the standard library can not satisfy my need). is it a good idea to creat a derived class to extend the standard library?
Note that readBytesUntil can block; to prevent that, you can use approaches as described in Robin's updated Serial Input Basics thread. It also might answer your second question.
ansami:
sterretje:
Read till 0x0A. Next strip of the 0x0D.
thanks a lot. It is really a good and clear tutorial for serial and helps me a lot.
byte n = Serial.available();
if (n != 0)
byte m = Serial.readBytesUntil('\n', myData, 50);//0x0A(\n) is not saved
byte x1 = myData[m-1];
if(x1 == '\r')//0x0D
myData[m-1] = '\0' ; //inserted null character
Serial.println("Message received with 0x0D0A as terminator.");
Serial.println(myData);
Yep, it is a method to solve this problem. And your code suits the situation of my question well. However, after reading the tutorialSerial Input Basics which sterretje suggested, I think it can be better in my situation for two reason:1. The funtion readBytesUntil() is blocking function. 2. Two-bytes terminator is used because one of 0x0A and 0x0D may show in data(sorry for my defective expounding).
ansami:
If it's a self-defined protocol why add the complexity of a 2-byte terminator/
I don't think this will work to compare two arrays
if (rc != endMarker) {
If you insist on using two end-markers then the correct procedure is to read an extra byte when the first marker is detected and then check that extra byte for the second end-marker.
Robin2:
I did think of that but I assumed that a '\r' on its own might legitimately occur within the data - if not there is no need for a 2-byte terminator.
When numerical data are transmitted in ASCII, there are only frames for 0 - F (0x30 - 0x39, 0x41 - 0x46). How, \r (0x0D) or \n (0x0A) could appear there as an element of the data?
When text data are transmitted in ASCII, there are only frames for the printable charterers of the English Language (A- Z, a -z, numerals, punctuation marks, special charcaters). How, \r or \n could appear there as an element of the data?
GolamMostafa:
Maybe the data is not exclusively human readable text.
I assume the OP has some reason for the complication of a 2-byte end marker.
Robin2:
...R
yep, it is a self protocol of a device i got which consist largely of ASCII. But there is one byte in the protocol for slave machine device address which can be data in 0~255 theoretically. I think this is the reason of using 2 bytes terminator.
I fully agree that your code is good for this purpose. however i was puzzled why 2 arrays can not be campared . Is there any good material for learning?thanks a lot.
Robin2:
If you want to use a real library, you can use SerialTransfer.h to automatically packetize and parse your data for inter-Arduino communication without the headace. The library is installable through the Arduino IDE and includes many examples.
Here are the library's features:
This library:
can be downloaded via the Arduino IDE's Libraries Manager (search "SerialTransfer.h")
works with "software-serial" libraries
is non blocking
uses packet delimiters
uses consistent overhead byte stuffing
uses CRC-8 (Polynomial 0x9B with lookup table)
allows the use of dynamically sized packets (packets can have payload lengths anywhere from 1 to 254 bytes)
can transfer bytes, ints, floats, and even structs!!
