serial communication with 4*16 LCD
hello friends,
i am just beginner with arduino.
i have successfully communicated 4 by 16 LCD with one to one connection with LCD pins d4, d5, d6, d7 to Arduino pins 5, 4, 3, 2 as in example.
I found some lcds are serially enabled, i mean to communicate with just to pins Rx ant Tx.
So what is the intermediate logic that converts serial data into digital that understood by LCD?
How can i make my LCD serially enable? ( i mean with some kind of decoder or something?)
Thanks,
Bhargav.
Yes they have a special circuit on them to convert the data from serial to parallel. This is normally a small processor like the arduino.
You don't want to do that because there is only one serial port on a Uno and that is used in uploading sketches. If you want to use fewer pins then look at using the I2C bus and an I2C port expander. Read this:-
http://playground.arduino.cc/Code/LCD
