Serial communication with Matlab and Arduino
Hello...
I write code that can control pwm pin with Matlab program with serial communication.
This is arduino IDE code
/*                         PWMH0 641  Hz                                      */
int incomingByte = 0;
  pinMode(LED_BUILTIN, OUTPUT);
  PMC->PMC_PCER1 |= PMC_PCER1_PID36;                   // PWM power ON
  PIOC->PIO_PDR |= PIO_PDR_P3;                         // Set PWM pin to a peripheral
  PIOC->PIO_ABSR |= PIO_PC3B_PWMH0;                    // Set PWM pin peripheral type B for PWMH0 (Arduino pin 35)
 // PIOC->PIO_ABSR |= PIO_PC3B_TIOA0;
  PWM->PWM_CLK = PWM_CLK_PREB(0) | PWM_CLK_DIVB(2);    // select Frequency for clock B: Mck/2 = 42 MHz
  PWM->PWM_CH_NUM[0].PWM_CMR = PWM_CMR_CPRE_CLKB;      // The period is left aligned, clock source as CLKB on channel 0
  PWM->PWM_CH_NUM[0].PWM_CPRD = 65535;                 // Set the PWM frequency 42 MHz/PWM_CPRD = 641 Hz
  PWM->PWM_CH_NUM[0].PWM_CDTY = 32768;                 // Set the PWM duty cycle = (CPRD/CDTY) * 100 %
  PWM->PWM_IER1 = PWM_IER1_CHID0;                      // Interrupt on PWM Channel 0 counter
  NVIC_EnableIRQ(PWM_IRQn);                            // Enable interrupt
  PWM->PWM_ENA = PWM_ENA_CHID0;                        // Enable PWM channel 0
  if (Serial.available() > 0) {
                // read the incoming byte:
                incomingByte = Serial.read();
                Serial.print("I received: ");
                Serial.println(incomingByte);
                if (incomingByte==48){
                PWM->PWM_CH_NUM[0].PWM_CDTY = 1;
                // say what you got:
void PWM_Handler() {
  static uint32_t Count;
  PWM->PWM_ISR1;      // Clear status register
  if (Count++ == 641)
    PIOB->PIO_ODSR ^= PIO_ODSR_P27;
    Count = 0;
And Matlab code
delete(instrfindall);
% a = arduino('COM7','Due');
arduinoCom = serial('COM7','BaudRate',115200);
fopen(arduinoCom);
arduinoCom.BytesAvailable
fwrite(arduinoCom, '0')
fwrite(arduinoCom, '48')
fprintf(arduinoCom,'%s\n','0');
fprintf(arduinoCom,'%f\n','48');
fprintf(arduinoCom,'%f\n','0');
fprintf(arduinoCom,'%s\n','48');
pause(30)
And fprintf is
So when I run Matlab code, then nothing happen.
When I just run Arduino IDE's serial window and type number "0", then I received: 48 and then
pwm is become 3.2V (when not type, it record 1.6V cause of arduino due and duty cycle 50% and 3.2V is duty cycle 100%).
I record it with multimeter.
However in Matlab, I type lot of things that can see in Matlab code.
I type number 0 and number 48 but nothing happened and recorded just 1.6V .
Does there way to solve it?
instead of the IDE serial monitor consule, did you try using the MATLAB "Instrument Control Toolbox" to try to communicate with your arduino?
if yes, did it work? (on a side note, if it did work, you can auto-generate the MATlab code in there for the request you sent! :slight_smile: )
Umm.. I don't know the reason,
but When I click "write" button,
It says,
An error occured while communicating with the instrument.
dongjee33:
It says,
did you select the right comm port AND closed the arduino IDE/Serial Monitor?
Also check that you have set the COM port setting (baud rate, start/stop bits, etc) correctly in the toolbox
I think everything are okay.
Does it correct that go to Instrument Object/Interface Objects/Serial-COM7?
I go to Hardware/Serial and then scaning serial.
It showed( Port : COM7 , Identification:No instrument was identified)
Is this a problem? cause serial-COM7 is included in Instrument Objects
dongjee33:
sounds like like Matlab is not liking your arduino so some reason. not sure what's got wrong there....
you will need dig deeper there....
sorry, I'm out of ideas
Oh,
I just push disconnect button and click connect button, it working.
When I reconnect arduino then, click disconnect button then connect button.
Is there any reason??
sherzaad:
And didn't understand this meaning.
I want to write serial with matlab code in matlab script so does there any method to do this???
at least it working now! :slight_smile:
dongjee33:
in the Instrument Control Toolbox, you should find a tab where a script was auto-generated for the actions you executed in it.
You could then use this as your base for your actual script if your original script still does not work that is! :slight_smile:
I couldn't find auto-generate tab.
dongjee33:
what did you selected there!!! ?
if you select the Serial connection, don't you get a couple of tab/ menus where you can set/ send and receive your serial comms?
and if you go thru them you should find it. sorry cant remember the exact path off the top of my head... away from my MATLab PC at the mo
Oh, I find code that in there. It's session log.
But when I just move that code to script, it didn't work though it working in instrument control toolbox.
What's wrong?
It's working.. I just add pause(1) between set(obj1, 'BaudRate', 115200); and fopen. :slight_smile: :slight_smile: :slight_smile: :slight_smile:
