Serial Communication with Standard Firmata
I am working on a new software extension for a CAD package using Arduino. I would like to use the Standard Firmata to send/receive Serial data back and forth. My software is written in VB.NET and so far I can successfully send and receive serial data. Right now I have written a rudimentary Arduino program (like a crude custom firmata) to send sensor values out, and I am receiving CSV strings and parsing them successfully to control LED and servos. Nevertheless, I see the value of using the Standard Firmata. Is there someone out there that could assist me in understanding what serial values the Standard Firmata needs to receive (how many numbers, what order, etc) and also what SF sends out, etc. I imagine users like Massimo or eighthave would have a lot to offer this discussion. I have done a lot of research and hope some is willing to help. Right now I am using Standard Firmata V2.1 beta7. Thanks, hal9000
Just as a follow-up to my previous post - here is the Arduino code (my crude version of a custom Firmata) that I have written to send and receive serial data back and forth between Arduino and my VB.net code. I am using the Duemilanove so this code was written to write 6 Analog In values and 3 Digital In values. It also reads 6 PWM servo position values, and 3 digital out values. As you can see it would be much better to use the Standard Firmata though. I am trying to figure out whether it is best to use a "#include <Firmata.h>" similar to the example http://arduino.cc/en/Reference/Firmata, or simply upload the Standard Firmata to my board, then figure out how to communicate with it using serial /VB.net.
Thanks for any hints/assistance you may have!
#include <Servo.h>
#include <Wire.h>
#define BAUDRATE 115200
#define BUFFSIZE  1024    // buffer one command at a time, 12 bytes is longer than the max length
char buffer[BUFFSIZE];  // this is the double buffer
uint8_t bufferidx = 0; // a type of unsigned integer of length 8,16, or 32 bits
uint32_t DPin13, DPin12, PWM11, PWM10, PWM9, DPin8, PWM6, PWM5, PWM3;
 * GLOBAL VARIABLES
char *parseptr;
char buffidx;
int APin0 = 0; //declare all Analog In pins
int APin1 = 0;
int APin2 = 0;
int APin3 = 0;
int APin4 = 0;
int APin5 = 0;
int DPin2 = 0; //declare all Digital In pins
int DPin4 = 0;
int DPin7 = 0;
Servo Servo1; // declare all Servo (PWM out pins)
Servo Servo2;
Servo Servo3;
Servo Servo4;
Servo Servo5;
Servo Servo6;
int DinPin8 = 0; //declare all Digital Out pins
int DinPin12 = 0;
int DinPin13 = 0;
 * SETUP()
{  Serial.begin(BAUDRATE); // Start serial communication at 9600 bps
  for (int AinPin = 0; AinPin <= 5; AinPin++) // sets Analog In pin mode to INPUT
    pinMode(AinPin, INPUT);
  pinMode(2, INPUT); // sets Digital In pin mode to INPUT
  pinMode(4, INPUT);
  pinMode(7, INPUT);
  Servo1.attach(3); // attach all Servos to specific PWM pins
  Servo2.attach(5);
  Servo3.attach(6);
  Servo4.attach(9);
  Servo5.attach(10);
  Servo6.attach(11);
  pinMode(8, OUTPUT);
  pinMode(12, OUTPUT);
  pinMode(13, OUTPUT); // sets Digital Out pin mode to OUTPUT
 * LOOP()
  /// READ FROM ARDUINO
   APin0 = analogRead(0); // Read analog input pin
   APin1 = analogRead(1); // Read analog input pin
   APin2 = analogRead(2); // Read analog input pin
   APin3 = analogRead(3); // Read analog input pin
   APin4 = analogRead(4); // Read analog input pin
   APin5 = analogRead(5); // Read analog input pin
   DPin2 = digitalRead(2);  // Read digital input pin
   DPin4 = digitalRead(4);  // Read digital input pin
   DPin7 = digitalRead(7);  // Read digital input pin
   /// SERIAL WRITE FUNCTIONS
   // Sending Sensor Data (comma seperated) to Serial / GH
   Serial.print(APin0);
   Serial.print(","); // Send the value and a comma
   Serial.print(APin1);
   Serial.print(APin2);
   Serial.print(APin3);
   Serial.print(APin4);
   Serial.print(APin5);
   Serial.print(DPin2);
   Serial.print(DPin4);
   Serial.println(DPin7);
   delay(20); // Wait 100ms for next reading
  char c;    // holds one character from the serial port
  if (Serial.available()) {
    c = Serial.read();      // read one character
    buffer[bufferidx] = c;  // add to buffer
    Serial.print(c);//write raw data to serial for testing
    if (c == '\n') {
      buffer[bufferidx+1] = 0; // terminate it
      Serial.println(" eol");    // debug marker "end of line"
      parseptr = buffer;    // offload the buffer into temp variable
      DPin13 = parsedecimal(parseptr);    // parse the first number
      parseptr = strchr(parseptr, ',')+1;  // move past the ","
      DPin12 = parsedecimal(parseptr);    // parse the second number
      PWM11 = parsedecimal(parseptr);    // parse the third number
      PWM10 = parsedecimal(parseptr);    // parse the fourth number
      PWM9 = parsedecimal(parseptr);    // parse the fifth number
      DPin8 = parsedecimal(parseptr);    // parse the sixth number
      PWM6 = parsedecimal(parseptr);    // parse the seventh number
      PWM5 = parsedecimal(parseptr);    // parse the eighth number
      PWM3 = parsedecimal(parseptr);    // parse the ninth number
      Servo1.write(PWM11); // tell servo to go to position in variable 'servo1Degrees'
      Servo2.write(PWM10); // tell servo to go to position in variable 'servo2Degrees'
      Servo3.write(PWM9); // tell servo to go to position in variable 'servo3Degrees'
      Servo4.write(PWM6); // tell servo to go to position in variable 'servo4Degrees'
      Servo5.write(PWM5); // tell servo to go to position in variable 'servo5Degrees'
      Servo6.write(PWM3); // tell servo to go to position in variable 'servo6Degrees'
      if (DPin8 == 1) {    // if it is equal to 1
        digitalWrite(8, HIGH);      // then turn LED on
      else {
        digitalWrite(8, LOW);     // else turn LED off
      if (DPin12 == 1) {    // if it is equal to 1
        digitalWrite(12, HIGH);      // then turn LED on
      else {
        digitalWrite(12, LOW);     // else turn LED off
      if (DPin13 == 1) {    // if it is equal to 1
        digitalWrite(13, HIGH);      // then turn LED on
      else {
        digitalWrite(13, LOW);     // else turn LED off
      bufferidx = 0;      // reset the buffer for the next read
      return;        //return so that we don't trigger the index increment below
    // didn't get newline, need to read more from the buffer
    bufferidx++;    // increment the index for the next character
    if (bufferidx == BUFFSIZE-1) {  //if we get to the end of the buffer reset for safety
      Serial.print('!', BYTE);
      bufferidx = 0;
uint32_t parsedecimal(char *str)
  uint32_t d = 0;
  while (str[0] != 0) {
    if ((str[0] > '9') || (str[0] < '0'))
      return d;
    d *= 10;
    d += str[0] - '0';
    str++;
  return d;
Did you see this:
Looks something like what you are trying to (re)invent.
