Serial Communication with xbee 865LP
Hello,
I am trying to send data over xbee and and generate DO on arduino board.
First let me inform, i am using arduino equivalent board with ATMega8 ( so i think software serial is not available).
Second, i am using digi 865LP module to receive/transmit serial data .(Support Services | Digi International)
My set-up :
i have connected one xbee module by USB connector and set target module ID DH and DL ( you can find this para by selection XB8 in X-CTU )
then simply connected DOUT (of receiver xbee) to PIN 1 (Rx of arduino) and DIN (of receiver xbee) to PIN 0 (tx of arduino)
i hv downloaded following program in arduino, so if i send "1" from keayboard (ASCII) LED should turn ON.
int doPin = 13;
int inbyte = 0;
void setup(){
pinMode(doPin, OUTPUT);
if(Serial.available() > 0) {
inbyte = Serial.parseInt();
if (inbyte == 49){
digitalWrite(doPin, HIGH);
inbyte == 49 to convert ASCII "1" into integer "1"
used Serial.paseInt() - so other than integer data is ignored (like ENTER or MOUSE click)
if i am sending "1" from XCTU terminal (appears in blue) , it echos me back with red fonts (that means data is received by target module - i made such setting in target xbee) but LED on board is not glowing.
Then after i have tried to send "1" by "arduino serial monitor" again LED does not glow, but this time i am receiving "1." (One followed by dot) in XCTU terminal. Means data is getting transmit but program is not working - i guess.
please help me - My target is : to sense DIs from one arduino - transmit them by Xbee > receive them by xbee - generate DOs in another arduino.
Please let me know if further clarification is required in my above description.
Thanks,
Bhargav
If you send "1", the parseInt() method will return 1, not 49.
