Serial communication
Hi guys!
I'm new to arduino, I have the latest serial one. I want to blink the led with a delay, that I send to the arduino from my pc. If I send something from the arduino IDE, it send it as an ASCII character. So if I send 9, the LED will blink with delay(89); as in the ascii table or, if I send z it will blink with delay(122); and not with delay(9); I want to send for example 560, and the arduino should blink the led with delay(560);. How can I send the board a DEC number, and not only the ascii character code. Can I do a simple program with processing with a simple gui?
A trick I learned here on the forums, so I will pass it on,
while(Serial.available())
        c = Serial.read();
        if(c < '0' || c > '9') return;
        iValue = iValue * 10 + (c-'0');
So if you send string "560" iValue will equal the number 560.
Note you need to modify it for what you are doing, this is part of a function.
Something like this,
        c = Serial.read();
THANK YOU! =) I'm trying this out now. I'll post my experiences.
With the help of Jassper, I created this piece of code, that can read a full number with more than one digits. Well this is awesom for me! :sunglasses:
Can someone write a simple processing program for this purpose? sending numbers on on serial interface?
int ledPin = 13;                // LED connected to digital pin 13
int c = 0;
int i = 0;
int iValue = 0;
void setup()                    // run once, when the sketch starts
  pinMode(ledPin, OUTPUT);      // sets the digital pin as output
void loop()                     // run over and over again
  while (Serial.available())
              i++;
              if (i == 1) {
                iValue = 0;
              c = Serial.read();
              Serial.println(iValue);
              i = 0;
  digitalWrite(ledPin, HIGH);   // sets the LED on
  delay(iValue);
  digitalWrite(ledPin, LOW);    // sets the LED off
  delay(iValue);
