serial communication
hi plz tell me that in arduino uno can i use external serial.by means of transeiver?not use with usb cord?if yes so plz give me idea plz
What do you main with a transceiver ? A wireless module or the TX signal ?
You can use pin 0 (RX) and pin 1 (TX) for other devices, but then you can's use the serial monitor anymore, and uploading a sketch is a problem.
The SoftwareSerial creates extra serial ports on other pins.
You can use that extra serial port for other devices.
hi
can i use arduino uno with serial communication with external ,without using usb cable
OP you have been warned in the past about multiple cross-posting.
DO NOT CROSS POST, IT WASTES TIME.
No more warnings.
Hi all,
I’m having a problem with serial communication. I’m using a Arduino Mega board, BT module, Ultra Sonic range measurement module and 9 Degrees of Freedom - Razor IMU. They all are sending a diferent kind of data and I want to display all incoming data in Serial Monitor at the same time. For all those devices I have seperate codes and now I want to put them in one code and display data. So is there a posibility to do that?
Yes
But how? I put the BT code and Ultra Sonic range measurement module code in one code and I only Ultra Sonic range measurement module’s data…
const int NUMBER_OF_FIELDS = 3; // how many comma-separated fields we expect
int fieldIndex = 0;             // the current field being received
float values[NUMBER_OF_FIELDS];   // array holding values for all the fields
//const int pingPin = 7;
  Serial1.begin(115200); // Initialize serial port to send and receive at 9600 baud
  //Serial2.begin()
  if( Serial1.available()) {
    for(fieldIndex = 0; fieldIndex  < 3; fieldIndex ++)
      values[fieldIndex] = Serial1.parseFloat(); // get a numeric value
    Serial.print( fieldIndex);
    Serial.println(" fields received:");
    for(int i=0; i <  fieldIndex; i++)
       Serial.println(values[i]);
    fieldIndex = 0;  // ready to start over
  //long duration, cm;
  //pinMode(pingPin, OUTPUT);
  //digitalWrite(pingPin, LOW);
  //elayMicroseconds(2);
  //digitalWrite(pingPin, HIGH);
  //delayMicroseconds(5);
  //pinMode(pingPin, INPUT);
  //duration = pulseIn(pingPin, HIGH);
  //cm = microsecondsToCentimeters(duration);
  //Serial.print(cm);
  //Serial.print("cm");
  //Serial.println();
  //delay(100);
//long microsecondsToCentimeters(long microseconds)
 // return microseconds / 29 / 2;
