Hello All,
I have the following code that I am running on ESP8266.
const byte numChars = 64;
char receivedChars[numChars];
boolean newData = false;
void serialFlush(){
while(Serial.available() > 0) {
char t = Serial.read();
while(!Serial.available())
Serial.println(Serial.available());
recvWithStartEndMarkers();
Serial.println(receivedChars);
serialFlush();
delay(5000);
void recvWithStartEndMarkers() {
//server.send(200, "text/html", "<h1>Received 1</h1>");
static boolean recvInProgress = false;
static byte ndx = 0;
char startMarker = '<';
char endMarker = '>';
char rc;
while (Serial.available() > 0 && newData == false) {
rc = Serial.read();
if (recvInProgress == true) {
if (rc != endMarker) {
receivedChars[ndx] = rc;
//Serial.print(receivedChars[ndx]);
ndx++;
if (ndx >= numChars) {
ndx = numChars - 1;
else {
receivedChars[ndx] = '\0'; // terminate the string
ndx = 0;
newData = true;
}//recvInProgress
else if (rc == startMarker) {
recvInProgress = true;
}//else
}//while
//Serial.println(receivedChars);
All the code does is that it reads data from a serial port (through serial monitor) and rewrites it to the serial monitor.
When I run the code, it works without any issue for the first time. This is, I type something in between carrots and it rewrites it back to the serial monitor.
But, If I enter new string for the second time, it only return the first string. I don't seem to find the issue with the code. So I welcome and appreciate any suggestions.
Regards,
