Serial Communications help!
Hi everyone,
I'm working on a project. What I want to do is to control the Arduino board using the Serial Monitor. That is when I enter "a", it will do routine A. If entered ''b', it will do routine B.
I can actually do it now, but what I want now is that, for example, If I receive an "a" it will do routine a continuosly, until it reads a "b" on the serial monitor.
How can I do that? Continuosly doing a routine and checking the serial port at the same time? Please give me a sample code.
Thankyou!
you cannot do two things simultaneously (checking serial and doing something else) you have to do them alternatively
it could look like this ...
char command;
  Serial.println("my first command interpreter :) ");
 if (Serial.available() > 0)
    command = Serial.read();
  switch(command)
  case 'a' :
    a();
  case 'b' :
    b();
  case 'c' :
    c();
  default:
    Serial.println("unsupported command");
void a()
  Serial.println("ape");
  delay(100);
void b()
  Serial.println("bock");
  delay(100);
void c()
  Serial.println("cow");
  delay(100);
