Serial Connection between two Arduino's
Hello, I have a little issue, I have two arduino's connected together:
Arduino 1:
TX connected to Arduino 2's RX
RX connected to Arduino 2's TX
Code of arduino 1
  pinMode(13, OUTPUT);
  if(Serial.available() > 0)
    Serial.read();
    digitalWrite(13, HIGH);
    delay(100);
    digitalWrite(13, LOW);
Arduino 2's code
  delay(200);
  Serial.print("i");
What it should do is, when I press arduino 2's reset button, the LED on arduino 1 should turn on and off for a little while. But it does not work, does anyone know why?
Thanks in advance!
ikkentim
Did you connect the grounds together?
No, is it required? :~
ikkentim:
Yes...
