Serial connection with LabVIEW
Hey everyone. I'm trying to create a simple serial connection to get my Arduino Uno to communicate with LabVIEW. I'm trying to turn an LED on and off through the LabVIEW program. I've written a VI that sends either a 0 or 1 to the board, however the LED does not respond. Is there a problem with my sketch?
int ledPin = 3;
void setup() { Serial.begin(9600); pinMode(ledPin, OUTPUT); }
void loop() { int serialReading = 0; serialReading = Serial.read(); if (Serial.available() > 0) { serialReading = Serial.read(); digitalWrite(ledPin,HIGH);
else { }
Thanks.
Some simple test code that will turn the LED on the arduino board on and off.
// zoomkat 8-6-10 serial I/O string test
// type on or off in serial monitor. then send or enter
// for IDE 0019 and later
String readString;
        pinMode(13, OUTPUT);
        Serial.println("serial test 0021"); // so I can keep track of what is loaded
        while (Serial.available()) {
        delay(1);
      char c = Serial.read();
        readString += c;
      if (readString.length() >0) {
      Serial.println(readString);
    if (readString == "on") {
    digitalWrite(13, HIGH);
        Serial.println("Led On");
   if (readString == "off") {
    digitalWrite(13, LOW);
        Serial.println("Led Off");
        readString="";
modded your code
int ledPin = 3;
  char c = 0;
    c = Serial.read();
    if (c == '1')     // assuming you send character '1', not a byte with value 1
       digitalWrite(ledPin, HIGH);
    if (c == '0')
       digitalWrite(ledPin, LOW);
