Serial Control of LED's
Hello,
I am trying to learn about serial control. I modified the "Knight Rider" example from arduino.cc/en/Tutorial/KnightRider. The sketch works by typing the ASCII value in the serial monitor, which sets the value of "timer". My question is how can I stop the LED's from rapidly flashing when the sketch is first run and before any value is typed in the serial monitor? I also notice if I uncomment the code that will display the typed value, the sketch runs slow enough to notice a delay in the led flash pattern. Any help would be appreciated. the code is.
/* Knight Rider 3
 * This example concentrates on making the visuals fluid.
 * (cleft) 2005 K3, Malmo University
 * @author: David Cuartielles
 * @hardware: David Cuartielles, Aaron Hallborg
int pinArray[] = {2, 3, 4, 5, 6};
int count = 0;
int timer = 0;
void setup(){
  for (count=0;count<5;count++) {
    pinMode(pinArray[count], OUTPUT);
  if (Serial.available() > 0)
            // read the incoming byte:
   timer = Serial.read();
  for (count=0;count<4;count++){
   digitalWrite(pinArray[count], HIGH);
   delay(timer);
   digitalWrite(pinArray[count + 1], HIGH);
   delay(timer);
   digitalWrite(pinArray[count], LOW);
   delay(timer*2);
  for (count=4;count>0;count--){
   delay(timer);
   digitalWrite(pinArray[count - 1], HIGH);
   delay(timer);
   delay(timer*2);
  // Serial.print ("You entered ASCII value  ");
  // Serial.println(timer, BYTE); //print as a raw byte value
  // Serial.print ("Decimal Value =  ");
  // Serial.println(timer, DEC); // print as an ASCII-encoded decimal
  // Serial.print ("Hexidecimal Value =  ");
  // Serial.println(timer, HEX); // print as an ASCII-encoded hexadecimal
  // Serial.print ("Octal Value =  ");
  // Serial.println(timer, OCT); // print as an ASCII-encoded octal
  // Serial.print ("Binary Value =  ");
  // Serial.println(timer, BIN); // print as an ASCII-encoded binary
The value for timer is read from the serial port. It defaults to 0 until a value is read. Simply make it default to some other value.
Calling delay() with a value of 0 is a bad idea.
Thanks,
I just set "int timer = 100;" and the flash defaults to 100ms flash. I didn't realize that I could set a default delay and then change it in Serial.read.
