Serial Control over Processing
Hi all.
I have the following code in Arduino that when on initialisation it starts by blinking a led, and only when a command (letter) is sent over the Serial Monitor, the led stops blinking. The stop phase lasts for a little less than 2 minutes, and then starts blinking again, and so on.
The code works fine when I use the Serial Monitor. However, when I do the same in Processing (code below), the led receives the 'a' letter and stops blinking, but never starts again.
Can someone explain why??
#include <Wire.h>
#include "RTClib.h"
RTC_Millis RTC;
float startMin;
float setRandMin;
float count = 0;
int newCount = 0;
int led1 = 13;
char input;
boolean starter = true;
void setup () {
  pinMode(led1, OUTPUT);
  // following line sets the RTC to the date & time this sketch was compiled
  RTC.begin(DateTime(__DATE__, __TIME__));
  DateTime now = RTC.now();
  startMin = now.minute();
  setRandMin = 1;
void loop () {
  if (Serial.available()) {
    input = Serial.read();
  if (startMin != now.minute()) {
    count = count + 1;
  newCount = count / 60.;
  if (newCount >= setRandMin || starter) {
    float led1Bool = random (0, 2);
    if (led1Bool > 0.7) {
      digitalWrite (led1, HIGH);
    else {
      digitalWrite(led1, LOW);
    delay(200);
  else {
  if (input == 'A' || input == 'a') {
    starter = false;
    setRandMin = 1;
    count = 0;
/////// Processing Code //////////
import processing.serial.*;
Serial myPort;
println(Serial.list());
myPort = new Serial (this, Serial.list()[0], 9600);
void draw() {
void mouseReleased() {
myPort.write(65);
Why are you storing an integral amount in a float?
There is nothing in your code that makes ANY sense with floats.
Not sure if the float thing had anything to do with the issue, nevertheless, I have changed this inconsistency.
Still, when sending a Serial command via Processing, the led stops (initially correct), but fails to start blinking again after the specified amount of time.
Here is the example again.
#include <Wire.h>
#include "RTClib.h"
RTC_Millis RTC;
int startMin;
int count = 0;
int led1 = 13;
char input;
void setup () {
void loop () {
    count = count + 1;
  if (count >= 60 || starter) {
    else {
    delay(200);
  else {
    starter = false;
    count = 0;
So, I changed this:
To this:
while(Serial.available() > 0) {
char input = Serial.read();
And it works. Probably better to have a while loop checking...
I fail to see why you bother reading the serial port, when all you do it is throw the data away.
