Hello, I'm wrote this program recently to control a servo which has been modified for continuous rotation. But I couldn't figure out how to set a time for the servo to rotate. Eg: I want the servo to rotate to 180 degree position which makes the modified servo rotate continuously but how do I set a time limit like 5 seconds for example so that it does not continue to move on forever (i.e it stops rotataing after 5 seconds and waits for another command). I will using this with the roboduino.
#include <Servo.h>
int moveservo;
Servo servo1;
pinMode(3, OUTPUT);
Serial.println("Control your servo using serial");
Serial.println("Use , and . to control your servo!");
servo1.attach(3);
if (Serial.available() > 0) {
moveservo = Serial.read();
if (moveservo == 44) { servo1.write(180); };
if (moveservo == 46) { servo1.write(-180); };
if (moveservo == 32) { servo1.write(90); };
Thnx,
Aditya
