Serial data: 2 hidden/unreadable characters (EOL)
When sending something, anything, to the my Arduino via the serial monitor I constantly get 2 more characters that I sent, one of them is \r. I can't find the other and I don't know how to find it, sending the serial data back is useless as it's non-human readable... can anybody help?
This is what I use to read and show the number of received bytes:
Serial.print(Serial.readBytesUntil('\0', serialData, 31));
Mind that I have to stop at 31 even though my serialData is a 32 char array. For some reason I get all kind of weird stuff when I stop at 32 and go over the limit when sending something bigger than 32 characters.
You can change what the Serial Monitor appends, using the drop down in the lower right corner of the window.
Most likely, it \n.
There is never going to be a NULL in the input stream, when the stream comes from the serial monitor.
PaulS:
I thought this was to instruct the serial monitor how to interpret incoming stuff... no wonder it never worked :P. Thanks.
PaulS:
From what I've seen it seems there is actually is a NULL character at then end of the sent string via the serial monitor. Never mind, I effed up.
