Hey there,
I have two megas, one is a screen, one is a info collector.
The screen mega sends a request to info collector, info collector responds, data is compared and stripped, then it is displayed on screen. This is MOSTLY working correctly.
The only thing I am having issues with at the moment is that when I switch between pages, data from the previous page is concatenated to the data on the new page. For example, light reading on PAGE_ROOMREADINGS often displays 3 digits (771). When I switch to PAGE_RELAYREADINGS, the data displayed will be the correct data (a 0 or a 1), plus the last light reading (e.g. 071). I have tried clearing the CHAR_ARRAY, writing it with zeros, clearing every other string after the data has been displayed, but nothing is working.
Additional example:
Page Room Reading:
Temp: 22
Humidity: 49
Res Temp: 18
Light: 760
Then when I switch to Page Relay Reading (Where each relay should be a 0 or 1):
Relay 1: 02
Relay 2: 09
Relay 3: 08
Relay 4: 060
Can you spot why this is happening? Thank you!
int NEW_READING_AVAIL = 0;
String NEW_READING_DATA;
String mystring = "";
char character;
char CHAR_ARRAY[20];
long mymillis;
void setup(){
Serial.begin(19200);
Serial1.begin(1200);
myGLCD.InitLCD();
myGLCD.clrScr();
myGLCD.setFont(SmallFont);
myTouch.InitTouch();
myTouch.setPrecision(PREC_HI);
myButtons.setTextFont(SmallFont);
myButtons.setSymbolFont(Dingbats1_XL);
pinMode(13,OUTPUT);
digitalWrite(13,HIGH);
PAGE_MAIN();
mymillis=millis();
void SERIAL_UPDATE(){
if(Serial1.available()){
character=Serial1.read();
//Serial.print("Character: ");
//Serial.println(character);
mystring.concat(character);
//Serial.print("Data: ");
//Serial.println(mystring);
process(mystring);
void process(String DATA) {
if(DATA.startsWith("@")&&DATA.endsWith("#")){
DATA.remove(0,1);
DATA.remove(DATA.indexOf("#",1));
if(DATA.substring(0,3)=="RRR"){
DATA.remove(0,3);
NEW_READING_DATA=DATA;
NEW_READING_AVAIL=1;
mystring="";
}else if(DATA.substring(0,3)=="RRS"){
DATA.remove(0,3);
mystring="";
}else if(DATA.substring(0,3)=="RDS"){
DATA.remove(0,3);
mystring="";
void PAGE_ROOMREADINGS(){
myButtons.deleteAllButtons();
myGLCD.clrScr();
int butBack, pressed_button;
myGLCD.setColor(255, 0, 0);
myGLCD.fillRect(0, 0, 319, 20);
myGLCD.setColor(255, 255, 255);
myGLCD.setBackColor(255, 0, 0);
myGLCD.print("*** ControlBot V4.2.0 ***", CENTER, 3);
myGLCD.setBackColor(0, 0, 0);
myGLCD.print("ROOM READINGS", CENTER, 30);
myGLCD.print("Temperature: ", 10, 50);
myGLCD.print("Humidity: ", 10, 70);
myGLCD.print("Res Temperature: ", 10, 90);
myGLCD.print("Light: ", 10, 110);
myGLCD.print("MQ2: ", 10, 130);
butBack = myButtons.addButton( 10, 190, 300, 30, "Back");
myButtons.drawButtons();
while(1){
if(millis()-mymillis>1000){
Serial1.write("@RRR#");
mymillis=millis();
SERIAL_UPDATE();
if(NEW_READING_AVAIL==1){
int i=0;
NEW_READING_DATA.toCharArray(CHAR_ARRAY,20);
char *p=CHAR_ARRAY;
char *str;
while((str=strtok_r(p,",",&p))!=NULL){
switch (i){
case 0:
myGLCD.print(str,110,50);
i++;
case 1:
myGLCD.print(str,85,70);
i++;
case 2:
myGLCD.print(str,140,90);
i++;
case 3:
myGLCD.print(str,65,110);
i++;
case 4:
myGLCD.print(str,45,130);
i++;
NEW_READING_DATA="";
NEW_READING_AVAIL=0;
if(myTouch.dataAvailable()==true){
pressed_button=myButtons.checkButtons();
if(pressed_button==butBack){
PAGE_READINGS();
void PAGE_RELAYREADINGS(){
myGLCD.clrScr();
int butRelay1, butRelay2, butRelay3, butRelay4, butTimer1,butTimer2,butTimer3,butTimer4, butBack, pressed_button;
myGLCD.print("RELAY READINGS", CENTER, 30);
myGLCD.print("Relay 1: ", 10, 60);
myGLCD.print("Relay 2: ", 90, 60);
myGLCD.print("Relay 3: ", 170, 60);
myGLCD.print("Relay 4: ", 250, 60);
butRelay1 = myButtons.addButton(20, 95, 40, 40, "4", BUTTON_SYMBOL);
butRelay2 = myButtons.addButton(100, 95, 40, 40, "4", BUTTON_SYMBOL);
butRelay3 = myButtons.addButton(180, 95, 40, 40, "4", BUTTON_SYMBOL);
butRelay4 = myButtons.addButton(260, 95, 40, 40, "4", BUTTON_SYMBOL);
butTimer1 = myButtons.addButton(20, 140, 40, 40, "W", BUTTON_SYMBOL);
butTimer2 = myButtons.addButton(100, 140, 40, 40, "W", BUTTON_SYMBOL);
butTimer3 = myButtons.addButton(180, 140, 40, 40, "W", BUTTON_SYMBOL);
butTimer4 = myButtons.addButton(260, 140, 40, 40, "W", BUTTON_SYMBOL);
while(1){
Serial1.write("@RRS#");
mymillis=millis();
SERIAL_UPDATE();
int i=0;
char *p = CHAR_ARRAY;
char *str;
switch (i){
case 0:
myGLCD.print(str, 35, 75);
i++;
case 1:
myGLCD.print(str, 115, 75);
i++;
case 2:
myGLCD.print(str, 195, 75);
i++;
case 3:
myGLCD.print(str, 275,75);
i++;
PAGE_READINGS();
