Serial Data flush? - GPS/GSM Module serial communication...
Hey,
i am very much a total beginner in programming. So i have a question about a function i have written here.
I am using a Teensy and a A7 GPS/GSM Module, to build a GPS tracker. the NMEA data comes over "Serial2". my Debug output is "Serial". What i want to achieve is a function wich i can call and i get the last valid GPS coordinates back. So this is what i have done: (i know there is no "answer" right now...)
int8_t get_GPS() {
  int8_t counter, answer, looptrigger;
  long previous;
  bool newData = false;
  unsigned long chars;
  unsigned short sentences, failed;
  // For three seconds we parse GPS data and report some key values
  for (unsigned long start = millis(); millis() - start < 3000;)
    while (Serial2.available())
      char c = Serial2.read();
      //Serial.println("DEBUG");
      //Serial.write(c); // uncomment this line if you want to see the GPS data flowing
      if (gps.encode(c)) // Did a new valid sentence come in?
        newData = true;
  if (newData)
    float flat, flon;
    unsigned long age;
    gps.f_get_position(&flat, &flon, &age);
    Serial.print("LAT=");
    Serial.println(flat == TinyGPS::GPS_INVALID_F_ANGLE ? 0.0 : flat, 6);
    Serial.print(" LON=");
    Serial.println(flon == TinyGPS::GPS_INVALID_F_ANGLE ? 0.0 : flon, 6);
    Serial.print(" SAT=");
    Serial.println(gps.satellites() == TinyGPS::GPS_INVALID_SATELLITES ? 0 : gps.satellites());
    Serial.print(" PREC=");
    Serial.println(gps.hdop() == TinyGPS::GPS_INVALID_HDOP ? 0 : gps.hdop());
  gps.stats(&chars, &sentences, &failed);
  Serial.print(" CHARS=");
  Serial.println(chars);
  Serial.print(" SENTENCES=");
  Serial.println(sentences);
  Serial.print(" CSUM ERR=");
  Serial.println(failed);
  if (chars == 0)
    Serial.println("** No characters received from GPS: check wiring **");
  Serial.println(); Serial.println();
  return answer;
When i call that form loop() i get this outputted in my serial monitor:
LAT=50.975601
 LON=11.322467
 SAT=3
 PREC=710
 CHARS=2141
 SENTENCES=18
 CSUM ERR=0
which looks quite good, BUT there is something i dont understand: for testing i ran this function every second and what happens is, that i do get the actual position, but the "chars" and "sentences" counter grows extremely fast (for every char in the NMEA string...) Is that problematic?
So i tried to reset this counter every run, but i just have NO idea how!!
Or does this not matter at all? I am just concearned, that once this tracker runs for a couple of days some memory runs over and i am screwed...
Any Idea?
Cheers and Thanks!!!
When chars hits 4.2 billion, it'll roll over to 0. No big deal.
Ohh! I just had no idea what happens... it might explode :wink:
Cheers an Thanks!
