Serial data input via bluetooth
Hi!
I need little help.
//Connect ...
// arduino>>bluetooth
// D11   >>>  Rx
// D10   >>>  Tx
//Written By Mohannad Rawashdeh
//for http://www.genotronex.com/
// you will need arduino 1.0.1 or higher to run this sketch
#include <SoftwareSerial.h>// import the serial library
SoftwareSerial Genotronex(10, 11); // RX, TX
int BluetoothData; // the data given from Computer
  Genotronex.begin(9600);
  if (Genotronex.available()){
    Genotronex.println("For parameters input press: 1- Xm, 2- Ym and 3-W! ");
    BluetoothData=Genotronex.read();
    if(BluetoothData=='1')   // if number 1 pressed ...
      Genotronex.println("Input of speed - X direction: ");
    if (BluetoothData=='2')  // if number 2 pressed ....
      Genotronex.println("Input of speed - Y direction: ");
    if (BluetoothData=='3')  // if number 3 pressed ....
      Genotronex.println("Input of angular speed: ");
  delay(100);// prepare for next data ...
Do you have any idea how to input data via bluetooth?
In my project, I have 3 parameters (they need to be type of float):
  • Xm- speed in X direction
  • Ym- speed in Y direction
  • W - angular speed.
I want to change their values with bluetooth.
I made some basic for selecting.. but I don't know how to proceed. Do you have any idea?
Thanks, G
I made it!!
#include <AccelStepper.h>
#include "math.h"
float Xm;
float Ym;
float W;
char junk = ' ';
AccelStepper stepper1(1, 3, 2);   //MOTOR 1
int MS11 = 4;
int MS21 = 5;
int SLP1 = 6;
AccelStepper stepper3(1, 8, 7);   // MOTOR 3
int MS13 = 9;
int MS23 = 12;
int SLP2 = 13;
AccelStepper stepper2(1, 23, 22); // MOTOR 2
int MS12 = 24;
int MS22 = 25;
int SLP3 = 26;
AccelStepper stepper4(1, 28, 27); // MOTOR 4
int MS14 = 29;
int MS24 = 30;
int SLP4 = 31;
//preračun hitrosti
float Pi= 3.1416;
int koraki = 200; //število korakov motorja za en obrat
float r = 0.029; //polmer kolesa
float l = 0.09; //širina
float d = 0.09; //dolžina
float obseg= 2*r*Pi;    // obseg kolesa
  Genotronex.begin(115200); // begin serial output @ 115200 baud
  Genotronex.println("");
  Genotronex.flush();
  pinMode(2, OUTPUT);       //MOTOR 1
  pinMode(3, OUTPUT);
  pinMode(4, OUTPUT);
  pinMode(5, OUTPUT);
  pinMode(6, OUTPUT);
  pinMode(7, OUTPUT);       // MOTOR 3
  pinMode(8, OUTPUT);
  pinMode(9, OUTPUT);
  pinMode(12, OUTPUT);
  pinMode(13, OUTPUT);
  pinMode(22, OUTPUT);      // MOTOR 2
  pinMode(23, OUTPUT);
  pinMode(24, OUTPUT);
  pinMode(25, OUTPUT);
  pinMode(26, OUTPUT);
  pinMode(27, OUTPUT);      // MOTOR 4
  pinMode(28, OUTPUT);
  pinMode(29, OUTPUT);
  pinMode(30, OUTPUT);
  pinMode(31, OUTPUT);
  digitalWrite(MS11, LOW);   // MOTOR 1            MS1    MS2    (hitrost korakanja motorjev)
  digitalWrite(MS21, LOW);                  //     LOW    LOW    POLNOKORAČNO
  digitalWrite(MS12, LOW);   // MOTOR 2            HIGH   LOW    POLKORAČNO
  digitalWrite(MS22, LOW);                  //     LOW    HIGH   ČETRKORAČNO
  digitalWrite(MS13, LOW);   // MOTOR 3            HIGH   HIGH   OSMINSKOKORAČNO
  digitalWrite(MS23, LOW);
  digitalWrite(MS14, LOW);   // MOTOR 4
  digitalWrite(MS24, LOW);
  int MAX= 700;                  // MAX HITROST (steps/s)
  stepper1.setMaxSpeed(MAX);
  stepper2.setMaxSpeed(MAX);
  stepper3.setMaxSpeed(MAX);
  stepper4.setMaxSpeed(MAX);
  int pospesek= 50;
  stepper1.setAcceleration(pospesek);
  stepper2.setAcceleration(pospesek);
  stepper4.setAcceleration(pospesek);
  Genotronex.println("For parameters input press: Xm, Ym and W! ");
  Genotronex.println("Enter parameter value 'Xm', Press ENTER");
  while (Genotronex.available() == 0) ;
    Xm = Genotronex.parseFloat();
    Genotronex.print("Xm = ");
    Genotronex.println(Xm, DEC);
    while (Genotronex.available() > 0)  // .parseFloat() can leave non-numeric characters
      junk = Genotronex.read() ;  // clear the keyboard buffer
  Genotronex.println("Enter parameter value 'Ym', Press ENTER");
    Ym = Genotronex.parseFloat();
    Genotronex.print("Ym = ");
    Genotronex.println(Ym, DEC);
  Genotronex.println("Enter parameter value 'W', Press ENTER");
    W = Genotronex.parseFloat();
    Genotronex.print("W = ");
    Genotronex.println(W, DEC);
    float v1= -0.7071*Xm + 0.7071*Ym + 0.1273*W;
    float v2= -0.7071*Xm -0.7071*Ym + 0.1273*W;
    float v3= 0.7071*Xm -0.7071*Ym + 0.1273*W;
    float v4= 0.7071*Xm + 0.7071*Ym + 0.1273*W;
    float obrati1 = v1 / obseg; //obrati prvega kolesa
    float obrati2 = v2 / obseg; //obrati drugega kolesa
    float obrati3 = v3 / obseg; //obrati tretjega kolesa
    float obrati4 = v4 / obseg; //obrati četrtega kolesa
    float stobrt1 = obrati1;  //pretvorba float-->int
    float stobrt2 = obrati2;
    float stobrt3 = obrati3;
    float stobrt4 = obrati4;
    Genotronex.print("Obrati 1. kolesa = ");
    Genotronex.println(obrati1, DEC);
    Genotronex.println("\n");
    Genotronex.println();
    Genotronex.print("Obrati 2. kolesa = ");
    Genotronex.println(obrati2, DEC);
    Genotronex.print("Obrati 3. kolesa = ");
    Genotronex.println(obrati3, DEC);
    Genotronex.print("Obrati 4. kolesa = ");
    Genotronex.println(obrati4, DEC);
    float SetMotorSpeed1 = stobrt1*koraki;  // *200korakov na obrat/60sekund =korakov na sekundo
    float SetMotorSpeed2 = stobrt2*koraki;
    float SetMotorSpeed3 = stobrt3*koraki;
    float SetMotorSpeed4 = stobrt4*koraki;
    stepper1.setSpeed(SetMotorSpeed3);    // hitrost posameznega kolesa
    stepper2.setSpeed(SetMotorSpeed2);
    stepper3.setSpeed(SetMotorSpeed1);
    stepper4.setSpeed(SetMotorSpeed4);
    stepper1.setSpeed(SetMotorSpeed1);    // hitrost posameznega kolesa
    stepper3.setSpeed(SetMotorSpeed3);
    stepper1.runSpeed();
    stepper2.runSpeed();
    stepper3.runSpeed();
    stepper4.runSpeed();
    if( Xm && Ym && W ==0.0)
      digitalWrite(SLP1, LOW);
      digitalWrite(SLP2, LOW);
      digitalWrite(SLP3, LOW);
      digitalWrite(SLP4, LOW);
    if( Xm || Ym || W !=0.0)
      digitalWrite(SLP1, HIGH);
      digitalWrite(SLP2, HIGH);
      digitalWrite(SLP3, HIGH);
      digitalWrite(SLP4, HIGH);
Now I just have one problem!
How to make this parameters to stay in buffer untill I rewrite parameters? Because I regulate speed of motors with this numbers.
Thanks!
Have a look at the examples in Serial Input Basics. There is also a parse example to show how to store values in variables.
...R
Hi!
Last question. Why my acccelerating doesn't work?
#include "math.h"
float Xm;
float Ym;
float W;
char junk = ' ';
AccelStepper stepper1(1, 3, 2);   //MOTOR 1  driver, step, dir
int MS11 = 4;
int MS21 = 5;
int SLP1 = 6;
int MS13 = 9;
int MS23 = 12;
int SLP2 = 13;
int MS12 = 24;
int MS22 = 25;
int SLP3 = 26;
int MS14 = 29;
int MS24 = 30;
int SLP4 = 31;
//preračun hitrosti
float Pi= 3.1416;
  Genotronex.begin(9600); // begin serial output @ 115200 baud
  Genotronex.flush();
  pinMode(3, OUTPUT);
  pinMode(4, OUTPUT);
  pinMode(5, OUTPUT);
  pinMode(6, OUTPUT);
  pinMode(8, OUTPUT);
  pinMode(9, OUTPUT);
    float v3= -0.7071*Xm -0.7071*Ym + 0.1273*W;
    float v2= 0.7071*Xm -0.7071*Ym + 0.1273*W;
    float SetMotorSpeed1 = obrati1*koraki;  // *200korakov na obrat/60sekund =korakov na sekundo
    float SetMotorSpeed2 = obrati2*koraki;
    float SetMotorSpeed3 = obrati3*koraki;
    float SetMotorSpeed4 = obrati4*koraki;
    Genotronex.println(SetMotorSpeed1, DEC);
    Genotronex.println(SetMotorSpeed2, DEC);
    Genotronex.println(SetMotorSpeed3, DEC);
    Genotronex.println(SetMotorSpeed4, DEC);
    while (1)
      int MAX=700;                  // MAX HITROST (steps/s)
      float pospesek= 10;
      if (Genotronex.available()!=0)
