Serial Data Reading
If my Data Logger is going to log a long string like below:
$GPGGA,123519,4807.038,N,01131.000,E,1,08,0.9,545.4,M,46.9,M,,*47
Can the Serial.Read() handle ? It only return back int if there is any input.
What about stream.readString()?
How can I implement the code ?
Look at the examples in serial input basics. The second example should work. And you could probably use the third example if you use the $ as a start marker and (presumably) \n as the end marker.
There is also a parse example whoch you could adapt to pick out the different elements.
...R
When you read this reply, how do you handle it? Do you read a letter at a time?
