Hello~
I've encountered some problems having the serial monitor display the first value that I enter on the keypad. I'm trying to get the program to display the value that the user will enter into the keypad the moment it has been entered. However, only the second and third digit are being displayed. The first one keeps showing up as a blank.
I hope someone can help me! Thanks!
#include <stdio.h>
#include <Keypad.h>
#include <SimpleTimer.h>
char startrace, stoprace, gender;
int height1, height2, height3, height, weight1, weight2, weight3, weight, age1, age2, age, key, key1, key2;
double BMR, Calories;
unsigned long starttime, endtime;
long timetaken;
const byte ROWS = 4;
const byte COLS = 3;
char keys[ROWS][COLS] =
{ {'1','2','3'},
{'4','5','6'},
{'7','8','9'},
{'*','0','#'} };
byte rowPins[ROWS] = {13, 12, 11, 10};
byte colPins[COLS] = {9, 8, 7};
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
{ // Turn the Serial Protocol ON
keypad.setHoldTime(200);
keypad.setDebounceTime(200);
Serial.print("Press any key to start! (: \n");
key == '0'; }
char key = keypad.getKey();
if (key != NO_KEY)
{Serial.print("\nEnter your gender: ");
char key = keypad.waitForKey();
Serial.println(key);
if (key == '1')
{ gender = key;
Serial.print("You are a male\n");}
if (key == '2')
{ gender = key;
Serial.print("You are a female\n"); }
Serial.print("\nEnter your height:\n");
key = (keypad.waitForKey()-'0');
Serial.print(key);
key1 = (keypad.waitForKey()-'0');
Serial.print(key1);
key2 = (keypad.waitForKey()-'0');
Serial.print(key2);
height1 = (key)*100;
height2 = key1*10;
height3 = key2;
height = height1+height2+height3;
Serial.print ("\n");
Serial.print(height);
Serial.print("cm.");
Serial.print("\n\nEnter your weight:\n");
key = (keypad.waitForKey()- '0');
Serial.print(key);
key1 = (keypad.waitForKey()- '0');
Serial.print(key1);
weight1 = key*10;
weight2 = key1;
weight = weight1 + weight2;
Serial.print(weight);
Serial.print("kg.");
Serial.print("\n\nEnter age:\n");
Serial.print(key);
Serial.print(key1);
age1 = key*10;
age2 = key;
age = age1 + age2;
Serial.print(age);
Serial.print("\n\nReady to run?\n");
Serial.print("Press 1 to start!");
startrace = keypad.waitForKey();
if (startrace == '1')
{ starttime = millis();
Serial.print("\nStart time: ");
Serial.print(starttime);}
Serial.print("\n\nPress 2 to stop");
stoprace = keypad.waitForKey();
while (stoprace != '2')
{stoprace = key;}
endtime = millis();
Serial.print("\nStop time: ");
Serial.print(endtime);
Serial.print("\n");
timetaken= (endtime - starttime)/1000;
Serial.print("\nThe time taken is: ");
Serial.print(timetaken);
Serial.print("s.");
if (gender=='1')
{ Serial.print("\n\nYou are a male\n");
BMR = ((13.75*weight) + (5*height) - (6.76*age) + 66);
Serial.print("BMR value is:");
Serial.print(BMR); }
else if (gender=='2')
{ Serial.print("\nYou are a female\n");
BMR = ((9.56*weight) + (5*height) - (4.68*age) + 655);
Serial.print("BMR value: ");
Calories = (BMR/86400)*8*timetaken;
Serial.print("\nCalories burned: ");
Serial.print(Calories);
Serial.print("cal.");
