Serial Display, trying to display | / - \
I've been playing with my Arduio Nano now for a few day,
and i'm trying to have my serial display, display these characters ( | / - \ ) as
an indication that something is running,
but for some reason when it gets to \ it does not work.. I believe its a special character
I even tried using the decimal value of the ASCII character
my test code,
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);  // Set the LCD I2C address
char Show[] = {"|/-\0"};
//char Show[]{'|', '/', '-','\0'};
//int Show[4] = {124,47,45,92};             //             | / - \
int displaycount = 0;
  lcd.begin(16,2);   // initialize the lcd for 16 chars 2 lines, turn on backlight
  lcd.backlight();    // finish with backlight on
    displaycount = displaycount + 1;
    if (displaycount > 3){
      displaycount = 0;
    lcd.setCursor(15,1);
    lcd.print(Show[displaycount]);
//    lcd.print(char(Show[displaycount]));
    delay (1000);
thank's for any help
Nigel
Use
Serial.print("\\");
The \ is a special "escape" character used in things like tab ("\t") so it needs to be escaped itself.
Has the LCD backslash in character set? If not, you have to define it in CGRAM.
Budvar10:
from googling, it appears \ is not in it's ascii table.
I'll have to define my own... more googling.. :slight_smile:
Thanks..
Use LCD.createChar() function.
{ 0x00, 0x10, 0x08, 0x04, 0x02, 0x01, 0x00, 0x00 },	// BACKSLASH
NOTE: Character 0-7 can be user defined.
It took a little while to figure it out,
I had a issue when using "createChar", it was not a function in the library
so some more googling, and its working now,
thanks..
#include <Wire.h>
char Show[5] = {" |/-"};
uint8_t SpecialChar [8]= { 0x00, 0x10, 0x08, 0x04, 0x02, 0x01, 0x00, 0x00 };
int displaycount = 1;
  lcd.createChar(0, SpecialChar);
    lcd.setCursor(0,0);
    lcd.print(displaycount);
      lcd.print(char(0));
      displaycount = 0;
    else{
    delay (1000);
