Serial Does Not Name A Type
I get the following error when I run the code below: "Serial Does Not Name A Type"
//#include <SoftwareSerial.h>
//#include <print.h>
//#include <print.cpp>
//#include <ProfileTimer.h>
#include <BigNumber.h>
//#include <BigNumber.cpp>
//BigNumber::begin(); //initialize library
Serial.begin (9600);
Serial.println ();
Serial.println ();
BigNumber::begin (40); // initialize library
BigNumber::setScale (15);
// char R0[32] = {0,0,0,0,0,0,0,0,0,0,1,0,0,0,0,0,0,0,0,0,0,1,1,0,1,1,1,0,0,0,0,0}; // default 0x02006E0
//int R1[32] = {0,0,0,0,0,0,0,0,0,0,1,0,1,0,1,1,0,1,0,1,0,1,0,1,0,1,0,1,0,0,0,1}; // default 0x0AD5551
// int R2[32] = {0,0,0,0,0,0,0,0,0,0,1,0,0,0,0,0,0,0,0,0,0,0,0,1,1,0,0,0,0,0,1,0}; // default 0x08006002
// int R3[32] = {0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,1,1}; // default 0x00000003
// int R4[32] = {0,0,0,1,1,0,0,1,0,0,0,0,0,0,0,0,1,0,0,0,1,0,1,1,1,0,0,0,0,1,0,0}; // default 0x32008B84
// int R5[32] = {0,0,0,0,0,0,0,0,1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,1,0,0,1,0,1}; // default 0x000800025
// int R6[32] = {0,0,1,1,0,1,0,1,0,0,0,0,0,0,0,1,0,0,1,0,0,0,0,0,0,1,1,1,0,1,1,0}; // default 0x035012076
// int R7[32] = {0,0,0,1,0,0,1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,1,1,1}; // default 0x012000007
// int R8[32] = {0,0,0,1,0,0,0,0,0,0,1,0,1,1,0,1,0,0,0,0,0,1,0,0,0,0,1,0,1,0,0,0}; // default 0x0102D0428
// int R9[32] = {0,0,0,1,1,0,1,0,0,0,0,1,1,0,0,1,1,1,1,1,1,1,0,0,1,1,0,0,1,0,0,1}; // default 0x01A19FCC9
// int R10[32] = {0,0,0,0,0,0,0,0,1,1,0,0,0,0,0,0,0,0,1,0,0,1,1,0,1,0,1,1,1,0,1,0}; // default 0x000C026BA
// int R11[32] = {0,0,0,0,0,0,0,0,0,1,1,0,0,0,0,1,0,0,1,1,0,0,0,0,0,0,0,0,1,0,1,1}; // default 0x00061300B
// int R12[32] = {0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,1,0,0,0,0,0,1,1,1,0,0}; // default 0x00000041C
//string sbuf[]={
// String sbuf[] = {"68","00.0","000","00","122","880","000","1","N","Y","Enable","Disable",
// "110","11","359","573","512","1536","16","777","216","61","44","110","677","0833","3333","3333","6800","000","000","1","Enable","4/5","2006E0",
// "AD5551", "8006002", "Disable", "Disable", "Disable", "0", "3", "Digital Lock Detect", "Disable", "0.900", "Differential", "3.0v", "Positive", "Disable", "Disable", "Disable", "32008B84",
// "800025", "Fundamental", "Enable", "9", "Disable", "Enable", "Enable", "+5dBm", "Enable"};
//String sbuf2[] = {"Disable",
//"35012076", "REFin", "Disable" ,"5.0ns","Frac-N", "12000007", "102D0428", "Enable", "26", "103",
//"30", "12", "2840", "592", "1A19FCC9", "Enable", "154", "99", "417", "Enable", "Enable", "C026BA", "613008", "0", "0",
//"41C", "60", "00.0", "000", "00", "60", "10.0", "000", "00", "1", "100", "40", "00.0", "000", "00", "41", "00.0", "000", "00", "100", "1"};
// test multiplication
BigNumber Integer = 110;
BigNumber FRAC1 = "11359573";
BigNumber FRAC2 = "512";
BigNumber MOD2 = "1536";
BigNumber MOD1 = "16777216";
BigNumber PFD = "61440000";
Serial.println (1000.555);
BigNumber N11 = FRAC2 / MOD2;
BigNumber N1 = FRAC1 + N11;
BigNumber N2 = N1/MOD1;
BigNumber N3 = Integer + N2;
BigNumber N4 = PFD * N3;
//BigNumber testd = "100.5666666666666666666666666666655";
//char s = testd.toString();
Serial.println (N11);
Serial.println (N1);
Serial.println (N2);
Serial.println (N3);
Serial.println (N4);
// Serial.print("ddd = ");
// Serial.print(s);
Serial.println("");
int i;
// for (i=0;i<=60;i++){
// Serial.println(sbuf
String N7 = getHex("1000");
Serial.println(N7);
String getHex (String Binary)
  • { String rest("0x"), tmp,chr="0000"; *
  • int len = Binary.length()/4;*
  • //chr = chr.substring(0,len);*
  • //Binary = chr+Binary;*
  • for (int i = 0; i<Binary.length();i+=4)*
  • { tmp = Binary.substring(i,4);*
  • if (!tmp.compareTo("0000"))*
  • rest = rest + "0";*
  • else if (!tmp.compareTo("0001"))*
  • rest = rest + "1";*
  • else if (!tmp.compareTo("0010"))*
  • rest = rest + "2";*
  • else if (!tmp.compareTo("0011"))*
  • rest = rest + "3";*
  • else if (!tmp.compareTo("0100"))*
  • rest = rest + "4";*
  • else if (!tmp.compareTo("0101"))*
  • rest = rest + "5";*
  • else if (!tmp.compareTo("0110"))*
  • rest = rest + "6";*
  • else if (!tmp.compareTo("0111"))*
  • rest = rest + "7";*
  • else if (!tmp.compareTo("1000"))*
  • rest = rest + "8";*
  • else if (!tmp.compareTo("1001"))*
  • rest = rest + "9";*
  • else if (!tmp.compareTo("1010"))*
  • rest = rest + "A";*
  • else if (!tmp.compareTo("1011"))*
  • rest = rest + "B";*
  • else if (!tmp.compareTo("1100"))*
  • rest = rest + "C";*
  • else if (!tmp.compareTo("1101"))*
  • rest = rest + "D";*
  • else if (!tmp.compareTo("1110"))*
  • rest = rest + "E";*
  • else if (!tmp.compareTo("1111"))*
  • rest = rest + "F";*
  • continue;*
  • return rest;*
void loop () { }
Might just need " " around the digits here:
[color=red]Serial.println(N7);[/color]
Can't do that outside a function.
thanks
