Serial Event Monitor for Alarm System with SoftwareSerial
Hi there,
I'm looking at making use of the SoftwareSerial library to primarily monitor the serial output of my alarm system. It sends out an event in a packet of 30 bytes with byte 30 being a checksum byte. There is no defined start and end byte. I'll probably need to implement a scrolling window method to find the first valid packet whereafter it should easy.
I need to be able to read this in via the SoftwareSerial library in a byte array form, and not in a char array. Having these is byte form will make my further parsing a lot easier.
Please if anyone can assist, it would be much appreciated.
PLease post your code sofar?
declare
uint8_t buffer[60];
if you have read 60 bytes you are sure you have captured a sequence of 30 ...
What baud rate do you use? SWserial is not the most reliable one. Is the HW serial occupied?
