Hello i have the following code witch is working well
<if (mySerial.find(0x01))>
So i test if in the buffer there is the number 01 Hexadecimal, but i would like to test 3 numbers hexadecimal as
<if (mySerial.find(0x01, 0x04 , 0x04))>....
How can this be done and is it possible ?
And what is the difference between Stream ?
Thanks
The Stream class is a common class that used by a few other classes to give them a few extra functions. For example the HardwareSerial class can also use the extra functions of the Stream class.
It is done this way: class HardwareSerial : public Stream
The Serial object for a serial port is a real object in code. The Stream class is not.
The functions of the Stream class are in Stream.h.
Do you want to find either one of those bytes, or a sequence of the three bytes ?
You can search for the sequence with: mySerial.find( "\x01\x04\x04")
Hi Thanks yes i want to look for a sequence of three bytes.
Can you explain a litlle the syntax why this is \x01 and not 0x01 ?
Can you tell me how to understand difference between object and class ? I think to understand this more i should go deeper in C+ language isn't it ?
A class is a description of how it should look, the blueprint.
A object is the actual "variable" that has a memory location. It is not just a "variable" because there are also functions in it.
See for example the example sketch "sweep": https://www.arduino.cc/en/Tutorial/LibraryExamples/Sweep
#include <Servo.h>
Servo myServo;
The "Servo.h" has the definition for the class here. It is accompanied by "Servo.cpp".
The line "Servo myServo
" creates the object "myServo" of the class "Servo".
It is the same as "
int data
", which creates the variable "data" of the type "int".
In the C++ language, a variable value can be a decimal, a hexadecimal, a binary, a character and maybe some more:
byte data = 1; // decimal integer
byte data = 0x01; // hexadecimal value
byte data = 0b00000001; // 8-bit binary value
byte data = 'A'; // Ascii value of 'A', which is 0x41
When a string is used, the so called "escape character" is a backslash.
char myText[] = "Hello World"; // Hello World
char myText[] = "Hello \x41 World"; // Hello A World
char myText[] = "Hello \x41 \"World\""; // Hello A "World"
There are explained here: Escape sequences - cppreference.com
Let's have some fun.
You know an array of 32 integers is this: int myData[32];
For a class it is exactly the same: Servo myServo[32];
Let's put those 32 objects in action: https://wokwi.com/arduino/projects/305336312628511297 (in the middle-upper of the screen is the start button).
Great thanks it's working well, and thanks for your explaination
