How do I go about creating a serial frame in the Arduino language? I want to communicate between two Arduinos, using the RX and TX pins.
Example:
Analog in 0-5 on the transmitting Arduino needs to be read by the receiving Arduino. These need to by synced up some how, don't they? The the best way would be to make frames for this, correct?
What are frames? You mean some kind of message protocol?
As in send 4 bytes over (since analog read is 10 bits), first 2 bytes the opposite of the second 2, the reciever ANDs them together, if result is 0 it sends them back to show a good message was received? Use the upper bits to make sure 00 00 doesn't go out.
A frame is simply a series of bytes in a format that has been agreed on by both ends of the comms link. What Crossroads suggests is as good an example as any for a very simple application and even has some error checking and acknowledging which most protocols at this level don't.
which would send say "<11234>" and the receiver splits the 1 and the 1234 to get the pin number and the value. The < syncs the receiver and tells it to start reading characters and the > tells it to stop and parse the data. If the data is fixed length you don't need the >.
A more sophisticated version may be like this
Which has addressing, a frame sequence counter, data length, command and a CRC.
Really it's up to you to decide now you want to do it. Do a search for "communicating between two Arduinos" or some such, this comes up about twice a day.
Graynomad:
______
Rob
That is exactly what I am looking for. I want something that has addressing, and data. Do you know how I would code both ends?
If you're referring to the frame in the graphic I have code to create and transmit that but it's still very much in an alpha state and I haven't even started writing the receive code.
I can cut some parts from the code and post it but it will be specific to my applicaiton and may not make much sense outside that.
As you need addressing I take it you're doing some form of multi-drop network. What is the application?
Below is some simple code that uses an end of data packet marker.
//zoomkat 9-9-10 simple delimited ',' string parce
//from serial port input (via serial monitor)
//and print result out serial port
// CR/LF could also be a delimiter
String readString;
//expect a string like wer,qwe rty,123 456,hyre kjhg,
//or like hello world,who are you?,bye!,
while (Serial.available()) {
delay(1); //small delay to allow input buffer to fill
char c = Serial.read(); //gets one byte from serial buffer
if (c == ',') {break;} //breaks out of capture loop to print readstring
readString += c; //makes the string readString
if (readString.length() >0) {
Serial.println(readString); //prints string to serial port out
//do stuff here
readString=""; //clears variable for new input
The application is a large led board. I have one arduino that converts Ethernet to whatever, currently UART. The other arduino I have is designated for driving TLC5940's. I have the ethernet code working great. I just need a way to send data from arduino to arduino. I want an address and a value.
For the communication, you could appropriately connect the arduino serial ports together. As to address and value, you could send a128, where the "a" is an address and the "128" is the value.
What would be the command for receiving a Serial.write for the value, and Serial.print for the address? Serial.read only seems to work with Serial.write.
Could you give an example of the code? The only way I see it can be done is with if statements. Would I put in a Serial.read in the if statement to get the address, and then another to get the value?
An if statement has a conditional section and a body, that may consist of a single statement or multiple statements. The Serial.read() MIGHT be part of the body of an if statement, but I can't imagine what the conditional part would be.
The value is being sent as an array of characters. They will need to be read and stored in a char array, NULL terminated of course, and that array passed to atoi() to convert it back to an int.
How do you know when the end of the value has been received?
If you have binary data that makes it harder to differentiate between data and delimiters. In my pretty picture above the value 0x40 is a sync character, of course that's a valid data character as well so if you start reading chars half way through a frame you could get all screwed up, I use some low-level timing to detect an idle line but that's all way too much for your app I would think.
So you might find it easier to stick with ASCII representations of the data and use atoi() on the receiving end to reconstruct the data.
There must be 1000s of examples in this forum by now, this problem is raised every few days. Have a search for something like "communication between two arduinos"
How do I read that and interpret it on the receiving end?
Did you try the code I posted? You probably don't need delimiters on both ends of the data to just communicate between two arduinos. As to working code with two delimiters, people will tell you you need it, but they've never posted working code that I remember.
char buf[8];
uint8_t bufPtr = 0;
void flush() {
bufPtr = 0;
for (uint8_t i = 0; i < 8; i++) {
buf[i] = ' ';
void process() {
// if the string is the right length
if (strlen(buf) == 3) {
// the first byte is the pin number
uint8_t pinNum = buf[0];
// the next two bytes make up the pin value
uint16_t pinVal = (buf[1] << 8) | buf[2];
// do something
// reset the buffer
flush();
// read the byte in
// if it is the start character, reset the buffer
if (c == '<') {
flush();
// if it is the end character, or the buffer isn't long enough
} else if (c =='>' || bufPtr >= 8 - 1) {
// terminate the string
buf[bufPtr] = '\0';
// process the buffer
process();
// otherwise
// append to the buffer
buf[bufPtr] = c;
bufPtr++;
This works with delimiters on both ends - it also doesn't use the String class, so no dynamic memory pains =).
void flush() {
bufPtr = 0;
buf[i] = ' ';
void process() {
// do something
// reset the buffer
flush();
// read the byte in
if (c == '<') {
flush();
buf[bufPtr] = '\0';
process();
// otherwise
buf[bufPtr] = c;
bufPtr++;
How would the receiving end work with multiple input pins? From what I see, you only are sending the value of a single pin.
