Serial.funduntil()
  if(Serial.available())
  {if(Serial.findUntil("like","do"))
  Serial.println("found");
  Serial.println("not found");
input:like do like actuall output: found not found found
expected output: found
because in that bunch of stream after the terminator string "do"it should not read next coming string.am i right.
http://arduino.cc/en/Serial/FindUntil
i have read that link what there said is
Serial.findUntil() reads data from the serial buffer until a target string of given length or terminator string is found.
here even after reading my terminator string"do".it continues reading .thats little confusing
Please spent some time to get a proper layout of your code that makes it far more readable. Proper indentation can be done by pressing CTRL-T in the IDE Add spaces and empty lines to separate logic blocks.
  if (Serial.available() > 0)
    if ( Serial.findUntil("like","do") )
Be aware, this is the same sketch but not readable. The compiler does not need spaces, we humans do.
void setup(){Serial.begin(9600);}void loop(){if(Serial.available()>0){if(Serial.findUntil("like","do")){Serial.println("found");}else{Serial.println("not found");}}}
