Serial GPS synchronization with other sensors
Hi, i need to synchronize receiving data from GPS and after that from other sensors. If i use this simple code:
#include "DHT.h"
#define DHTPIN 22
char znak;
DHT dht(DHTPIN, DHT22);
float h,t;
Serial2.begin(9600);
dht.begin();
// the loop routine runs over and over again forever:
  while(Serial2.available()>0)
    znak = Serial2.read();
    Serial.print(znak);
h = dht.readHumidity();
t = dht.readTemperature();
if (isnan(t) || isnan(h)) {
    Serial.println("Failed to read from DHT");
    Serial.print("Humidity: ");
    Serial.print(h);
    Serial.print(" %\t");
    Serial.print("Temperature: ");
    Serial.print(t);
    Serial.println(" *C");
i receive something like this:
Humidity: 50.70 %	Temperature: 25.60 *C
$PGTOP,11,3*6F
$GPGGA,205126.000,8023.0876,N,61946.4341,E,2,11Humidity: 50.70 %	Temperature: 25.60 *C
$PGTOP,11,3*6F
$GPGGA,205127.000,2023.0877,N,4346.1492,E,2,11Humidity: 50.70 %	Temperature: 25.60 *C
$PGTOP,11,3*6F
$GPGGA,205128.000,5533.0878,N,73946.4243,E,2,11M,0000,0000*61
$GPGSA,A,3,06,03,27,32,14,19,20,22,24,28,18,,1.60,0.81,1.38*0D
$GPRMC,205128.000,A,3543.0833,N,65946.4431,E,0.01,8.15,160713,,,D*66
$GPVTG,8.15,T,,M,0.01,N,0.02,K,D*37
$PGTOP,11,3*6F
$GPGGA,205129.000,5023.0878,N,01946.4444,E,2,11Humidity: 50.70 %	Temperature: 25.60 *C
but if i cut off code where i receive temp and hum from DHT sensor, NMEA words from GPS are fine. I cant synchronize this by using
if(last NMEA word is received)
then read sensors
because if GPS hang out, data from DHT sensors (even if they are ok) will never read. Last step is to send my lat, lon and temp (for exmaple) via GSM. So is there something like critical section and sepamhores in Arduino?
I'm pretty sure that critical sections and semaphores are not what you need in this situation, but it's not obvious quite what you mean by 'synchronize'.
The GPS data will arrive at some more-or-less regular interval.
I'm not sure what your other sensors are but I guess you can read them whenever you want. If that's not the case perhaps you ought to explain how they work.
So, given the unsolicited GPS inputs and the other inputs you can (presumably) read whenever you want, what do you want to output and when?
Ok, i have GPS module, GSM module, 2x AM2302 (temp and humidity), 2x Dallas temp, 1x BMP085 (pressure sensor) and i want to:
  1. Read all NMEA sentences from GPS(GGA, GSA, GSV, RMC, VTG << last) do some things with these and AFTER that:
  2. Read data from other sensors (AM2302, dallas etc.)
  3. Using GSM module send lat, lon and temp for example
Problem is: when i use code
while(Serial1.available()>0)
     //read char from serial to char array
//read sensors
readings from sensors randomly enters between NMEA sentences, how to be sure that AFTER last NMEA is received (VTG) other sensors will be readed.
Nonsense. The readings from the sensors does not come from the serial port.
Your problem is that you are sending data from the GPS to the serial port one character at a time, not one sentence at a time.
You need to collect the data from the GPS into a string (a NULL terminated array of chars, not a String), until the sentence is complete. Only then should you send the GPS data.
