Hello, I am new to arduino. The code I wrote is supposed to power up an rgb light, electric motor (to create a garage door for a house), security system and IR temperature sensor.
For some reason I keep getting the error:
exit status 1
Compilation error: 'Serial' does not name a type
I have tried to rectify it by adding " #include<Serial.h> "
But this just gives the error:
exit status 1
Compilation error: Serial.h: No such file or directory
I am stuck. Here is my code:::
#include<Servo.h>
Servo myservo;
int count=0;
int pos;
pinMode(3,OUTPUT);//Blue LED
pinMode(5,OUTPUT);//Green LED
pinMode(6,OUTPUT);//Red LED
pinMode(2,OUTPUT);//Relay-Fan
void loop(){
// *******RGB Code********
if(count<10){
digitalWrite(3,HIGH);//Blue LED
digitalWrite(5,LOW);
digitalWrite(6,LOW);
delay(250);
else if(count<20){
digitalWrite(3,LOW);
digitalWrite(5,HIGH);//Green LED
else if(count<30){
digitalWrite(6,HIGH);//Red LED
delay(250);
else if(count<40){
delay(250);
else if(count<50){
count=0;
count++;
//---Temp control code-------------
int tempSensor = analogRead(A0);
Serial.println(tempSensor);
if(tempSensor<500) {
digitalWrite(2,HIGH);
else {
digitalWrite(2,LOW);
digitalwrite(6, HIGH):
else if (count < 50) {
count = 0;
count++;
//#############Open Garage Door###############
if(digitalRead(10)&&digitalRead(12)){//nothing outside and nothing inside = close door
goTo(180);
else if(!digitalRead(10)&& digitalRead(12)){//something outside and nothing inside
goTo(100);}
else if(!digitalRead(10) &&!digitalRead(12)){//something outside and inside
goTo(100);
else if(digitalRead(10) && !digitalRead(12)){//nothing outside and something inside
goTo(100);
//&&&&&&&&&&&&&&&Security System&&&&&&&&&&&&&&
if(digitalRead(7)==true){//door is open
digitalWrite(13,LOW);
tone(11,1000);
else{ //door is closed
digitalWrite(13,HIGH);
noTone(11);
delay(100);
void goTo(int state){//open 100 degrees; close 180 degrees
if (pos < state) {
while (pos < state) {
pos++;
myservo.write(pos);
delay(15);
while (pos > state) {
pos--;
myservo.write(pos);
delay(15);
