Serial I/O Help
Hello!
I just got an Arduino Duemilanove a few weeks ago. I need some help with Serial Input. I want to be able to type in a string and have the serial monitor output it back. I was able to do it with numbers, but haven't been able to do it with a string without printing the increments. (ex. I input truck, output is t tr tru truc truck)
I want to be able to echo the string WITHOUT any header/footer chars, and, if possible, not have a set max. length.
What I want is:
Input: String Echoing Program Test
Output: String Echoing Program Test
But I only want the output to display once-- not repeat over and over again.
Here's what I have so far.
#include <WString.h>
int length;
char temp;
String outString = String(60);
int stat = 0;
void setup () {
  Serial.flush();
void loop () {
  if(Serial.available() > 0 && stat == 0) {
    delay(5);
    length = Serial.available();
    Serial.println(length);
  else if (Serial.available() > 0) {
    while(Serial.available() < 0) {
      temp = Serial.read();
      outString.append(temp);
      stat = 1;
      delay(5);
  else if (stat == 1 && length == outString.length()) {
    Serial.println(outString);
    stat = 0;
    outString = "";
    Serial.flush();
By the way, I know C and C++.
Thanks in advance.
If you know C/C++, you are way ahead of me! Anyhow the looping examples generally given caused me confusion. After tinkering for a while I managed to put together the below simple code that uses the WString.h library (which apparently handles input array development internally).
//zoomkat 8-6-10 serial I/O string test
//type a string in serial monitor, then send or enter
String readString = String(100);
        while (Serial.available()) {
        delay(10);
          if (Serial.available() >0) {
        char c = Serial.read();
        readString.append(c); }
      if (readString.length() >0) {
      Serial.println(readString);
      readString="";
Thanks, zoomkat! It works!
