Ok, i almost have it, i am just a little hung up. I have two servos and want to show the arm position in degrees. I got it working but the serial monitor shows both servo1 and servo2 position consecutively. in other words, as i move servo1 and the serial monitor shows where the arm is... servo2 degrees is displayed in tandem with servo1. Not what i intend. I want to show individually what the position of where the servos are in relation to degrees. I am sure it is an easy fix. i do not play with serial often. here is the code:
void loop(){
val1 = analogRead(potPin1);//reads the value of the pot(0 to 1023)
val2 = analogRead(potPin2);
val1 = map(val1, 0, 1023, 0, 180);
val2 = map(val2, 0, 1023, 0, 180); //scales it down to 0 to 180
arm1servo.write(val1); //sets servo position according to scale
arm2servo.write(val2);
delay(15);//servos time to get there before next input
Serial.print("Servo1 degree ");
Serial.print("Servo2 degree ");
Serial.println(val1);
Serial.print(val2);
Sorry for not getting back soon John. I did what you said, and added a Serial.print("\n");
This seemed to seperate the lines well, however, the lines scroll super fast where you cant read the numbers.
Here's what i did next and it was interesting: I added a delay at the end of the serial codes and the servo moves to the speed of the delay I set. Ever heard of that? in my current code, there is already a delay of delay(15); for the servos. So my question is, how do i get the serial monitor to slow down without slowing down the servos?
the new code:
void loop(){
Serial.println("Servo2 degree: ");
Serial.print(val2);
Serial.print("\n");
Serial.println("Servo1 degree: ");
Serial.print(val1);
Serial.print("\n");
You can display the serial data less frequently. One way is to keep a variable per servo that stores the previous angle it was set to. Only print the serial info if the angle has changed by say five or more degrees. Or count how many times you've been round loop; at 500 times (or whatever), print the data and reset the count. Or use the blink without delay technique and just print once a second.
unsigned long LastPrintTime;
if(millis()-LastPrintTime > 1000)
Serial.print(val2);
Serial.print("\n");
Serial.print(val1);
Serial.print("\n");
LastPrintTime=millis();
