Serial input (presumably) reading newline, how can I fix this?
I am just working on a lab for school, but am encountering an issue that has caused me problems for years in programming, and I just want to squash this once and for all. I am writing example code that reads:
Can you tell me what's wrong with this picture:
  char input;
  if(Serial.available() > 0)
     input = Serial.read();
     if(input >= '0' && input <= '9')
       Serial.print("Number received: ");
       Serial.println(input);
       Serial.println("Not a number.");
This code was copied directly from an example on YouTube, but for me reads:
//Assuming I entered an 8, for example
Number received: 8
Not a number.
//It then waits - I enter a 7
Number received: 7
Not a number.
I am assuming it is reading the newline character. How can I fix this?
EDIT: I experimented by just hitting the “send” button instead of enter, but it is still giving the same message.
In your serial monitor select “No Line Ending” and/or insert the following in to your if statement block:
    else if(input == '\r' || input == '\n')
       //do nothing - ignore CR and NL
Why on earth do you care? If you only want to parse digits, the just throw anything else away. Or, specifically filter out CR (0x0d or '\r') and LF/NL (0x0a or '\n'). Then you don't care whether they are sent or not.
Regards,
Ray L.
@BigDaddyBlash, please do not cross-post. Threads merged.
Power_Broker:
In your serial monitor select "No Line Ending" and/or insert the following in to your if statement block:
You could, for testing purposes, to validate the idea that those characters are there, enhance P_B's code to print:
       Serial.println("Yep, got a CR or LF there alright");
Have a look at the examples in Serial Input Basics - simple reliable ways to receive data. There is also a parse example to illustrate how to extract numbers from the received text.
...R
