This is Tom Igoe’s code which I have tried to mess about with. I am fairly new to this, and I have read Serial Input Basics. However, this seems to offer a simpler solution to separating out data sent over serial - and it worked - occasionally, then not at all. Could someone tell me what the problem is with this code?
int w1 = 0;
int w2 = 0;
int w3 = 0;
int q1 = 0;
int q2 = 0;
int q3 = 0;
// Assumes a string in from the serial port like so:
// for example: "w5,200, 5 \n":
if (Serial.find("q")) {
q1 = Serial.parseInt(); // parses numeric characters before the comma
q2 = Serial.parseInt();// parses numeric characters after the comma
q3 = Serial.parseInt();
// print the results back to the sender:
Serial.print("q1: " );
Serial.print(q1);
Serial.print(" q2: ");
Serial.print(q2);
Serial.print(" q3: ");
Serial.println(q3);
else if (Serial.find("w")) {
w1 = Serial.parseInt(); // parses numeric characters before the comma
w2 = Serial.parseInt();// parses numeric characters after the comma
w3 = Serial.parseInt();
Serial.print("w1: " );
Serial.print(w1);
Serial.print(" w2: ");
Serial.print(w2);
Serial.print(" w3: ");
Serial.println(w3);
Well, for starters it’s not in code tags…The code tags make the code look
like this
when posting source code files. It makes it easier to read, and can be copied with a single mouse click. Also, if you don’t do it, some of the character sequences in the code can be misinterpred by the forum code as italics or funny emoticons.
If you have already posted without using code tags, open your message and select “modify” from the pull down menu labelled, “More”, at the lower left corner of the message. Highlight your code by selecting it (it turns blue), and then click on the “</>” icon at the upper left hand corner. Click on the “Save” button. Code tags can also be inserted manually in the forum text using the code and /code metatags.
Unless the sketch is too large, it’s better if you post your code, rather than attach it. When it’s attached, we have to download it, create a folder then open your code in our IDE. And afterwards, the folder remains unless we navigate to the “Temp” folder and manually remove it. It’s much easier to just view the code in your post.
You also haven’t told us any details about what worked/didn’t work.
burned_copper:
I think its worth understanding why your code doesn't work all the time, but after that I suggest you go back to the examples already linked.
if (Serial.find("q")) { ... }
else if (Serial.find("w")) { ... }
These "find" commands will block and eventually timeout, basically ping-ponging back and forth, so you don't know which "find" the hardware will be in when you happen to send your string down.
Also, those two find() functions will act on completely different sets of incoming data. They will NOT look for a 'q' and, if not found, go back through the same data looking instead for a 'w'
Because Serial.find("q") discards anything that isn't a "q". There may have been a "w" or something else useful but you don't know and you can't go back and recover that lost data.
(That must be a very old example. Robin's Serial Input Basics is up-to-date.)
burned_copper:
Thanks for the explanation, bDeters. Just for the asking, how can you know that serial.find times out and returns false? What makes it time out?
If the target aint in the input buffer and never arrives within a given amount of time, it returns false (usually by returning -1 or 0, but I don't know which it is for this specific function).
int q1 = 0;
int q2 = 0;
int q3 = 0;
// Assumes a string in from the serial port like for example: "q5,200, 5 \n":
switch (q1)
case 1: {
Serial.print("ITEM1: ");
Serial.print("parameter1: ");
Serial.print(q2);
Serial.print("\tparameter2: ");
Serial.println(q3);
case 2:
Serial.print("ITEM2:");
Serial.print("\tparameter1: ");
Serial.print(q2);
Serial.println(q3);
What else do you want to do with these parameters? Something useful I’m wagering!
The main issue you may see when you want the chip to do more than this one thing is that the Serial.find() and parseInt will STOP everything else from happening until it sees the “q” message or until it times out after 1 second. This means the speed at which you can do other things is gated by the speed you receive (or dont receive) these messages.
I can live with that as there will not be massive amounts of data or industrial useage.
TBH I don't know exactly what I'm making yet - I teach learners with special needs of various kinds, and I'm looking for some simple logic patterns that can produce sexy results. Also that I can understand!
This could for example drive a two wheeled robot, or some kind of crane contraption I'm thinking.
burned_copper:
This gives me the following. What am I missing?
If I was expecting to receive
I would use the 3rd example in Serial Input Basics and set the start-marker as 'q' and the end-marker as '\n'
And then use the concepts in the parse example to pick out the parts.
One of the advantages of doing it like that is that it makes it possible to view the received data before it is parsed in case things are not working properly.
Another advantage is that it won't try to parse a partial message and get stuck when the rest does not arrive.
Thanks for your help!
A robot, as opposed to a remote control toy, usually needs to sense its environment and react. It may have a sensor that stops it running into walls, for example. If it is waiting for a 'q' with that method then it will hit the wall.
Buy one of the hackable robot chassis like the ones Pololu sells. It will cost a hundred bucks or more. But the mechanics are all sorted out for you and there is example code so your kids can have it zipping across the desk in half an hour instead of spending all semester with no movement.
