Serial Input
I am working on a test bench code. I want to display “Enter PSI”… I then do calculations and store the calculated values to compare to the actual reading I am getting. I am running into an issue where I can input my PSI… it will do the calculations and compare to the real value…but it never resets. I can re-enter a value and it shows the new calculated values, but never sends out the pulse to get a new reading. I guess I am having a problem looping the program to restart so I can test another board.
I can tell it is not outputting a new pulse because I am viewing the outputs with my oscilloscope.
Any help is much appreciated. My code is below.
#include <math.h>
double INPUT_PSI;
double V_OUT_CALC;
double V_OUT_CALC_2;
//float HALF = 1/2;
double DAC_READING;
double EXPECTED_ANALOG;
double EXPECTED_ANALOG_PLUS;
double EXPECTED_ANALOG_MINUS;
int ADC_OUT;
boolean VALUE_ENTERED = false;
String readString;
int Signal = 7;
void setup ()
  pinMode(Signal, OUTPUT);
  pinMode(A0, INPUT);
Serial.println("Please enter PSI reading");
void loop ()
 // Serial.println("Please enter PSI reading");
  while (Serial.available())
      char p = Serial.read();
      readString += p;
      delay (2);
//        if (readString+=p == 'n/')
//      VALUE_ENTERED = true;
//      continue;
   if (readString.length () >0)
      INPUT_PSI = readString.toInt ();
      V_OUT_CALC = (INPUT_PSI * .02)+.5;
      Serial.println ("V OUT:");
      Serial.println (V_OUT_CALC);
      Serial.println(" ");
    //  Serial.println(INPUT_PSI);
      DAC_READING = (.003 * ((V_OUT_CALC/5)*1023)-.306);
      Serial.println ("DAC_READING:");
      Serial.println (DAC_READING);
      EXPECTED_ANALOG = ((DAC_READING+.306)/.003);
      Serial.println("EXPECTED_ANALOG:");
      Serial.println(EXPECTED_ANALOG);
      EXPECTED_ANALOG_PLUS = (EXPECTED_ANALOG *1.01);
      Serial.println("EXPECTED_ANALOG_PLUS:");
      Serial.println(EXPECTED_ANALOG_PLUS);
      EXPECTED_ANALOG_MINUS = (EXPECTED_ANALOG *.99);
      Serial.println("EXPECTED_ANALOG_MINUS:");
      Serial.println(EXPECTED_ANALOG_MINUS);
      delay(200);
      digitalWrite(Signal, HIGH);
      delay(20);
      ADC_OUT = analogRead(A0);
      Serial.println("ADC_OUT:");
      Serial.println(ADC_OUT);
     if (ADC_OUT >= EXPECTED_ANALOG_MINUS && ADC_OUT <= EXPECTED_ANALOG_PLUS)
      Serial.println ("PASS");
       Serial.println("FAIL");
       digitalWrite(Signal, LOW);
      INPUT_PSI = 0;
      V_OUT_CALC = 0;
      readString="";
      DAC_READING = 0;
      EXPECTED_ANALOG = 0;
      EXPECTED_ANALOG_PLUS = 0;
      EXPECTED_ANALOG_MINUS = 0;
      ADC_OUT;
//return;
You could use ParseInt : http://arduino.cc/en/Serial/ParseInt
And a NewLine is '\n'.
