Serial interface date capture and manuipulation, problem!!
Hi All,
I'm new to Adruino and C programming...
I have a project on the go at the moment and I'm using a v3 nano, I have the serial (RX) pin connected to my test bench setup and I'm pulling in the data from the serial port.
Set up as follows.
#define INPUT_PIN 2
//start serial connection
Serial.println("Starting Serial");
pinMode(INPUT_PIN , INPUT);
Serial.println("Start int ready");
So far so good.
Now on to the main loop.
char incomingByte;
if (Serial.available() > 0) {
incomingByte = Serial.read();
Serial.println(incomingByte, HEX);
So Far so good, this does indeed read my data from the Serial interface and when I use the Monitor I get this.
FFFFFFF0
4
68
48
FFFFFF80
54
Perfect, however, all of the above data is serial injected onto the port at location incomingByte[0] (if you get what I mean).
So, if I did not use "Serial.println" I would get 1 long stream of data on the monitor, not so good.
What I want to be able to do is read the data in as packet like so
FFFFFFF0 4 68 48 FFFFFF80 54
The problem that I have is that the data stream could be any size from 5 to 24 bytes long, so making a statement to read only the required amount is proving difficult.
Luckily the 2nd byte is in fact the packet length, but reading this in as a sequence can sometimes get blank entries (FFFFFFFF) in between the valid packets, so tying down the 2nd byte is not proving reliable.
So this (below) does not give a reliable result!!
char incomingByte;
char sequenceBytes[4];
// Serial.println(incomingByte, HEX);
sequenceBytes[0] = Serial.read();
sequenceBytes[1] = Serial.read();
sequenceBytes[2] = Serial.read();
sequenceBytes[3] = Serial.read();
sequenceBytes[4] = Serial.read();
Can anyone think of a way to push the values into an array (of the right size) so that I can then read it and then manipulate it, the way I want.
Sorry if this sounds vague, I know it is, but I'm stuck
John
Never mind, fixed
