Need a serial read out put for testing added to the code below I try and never seem to get it right. What I'm trying to do is print the temp sensed and if relays are high or low
Controller For outdoor air control (Factor Default 4 fan)
Arudino Duemilanove port connections:
Digital Inputs
Push button TB2 at port
Push button TEST at port
Analog Input
temperature sensors;
TempSens1 at port
Outputs
relay1 at port
relay2 at port
relay3 at port
// Pin Assignments:
const int TempSens1 = 2; // pin to which temperature sensor 1 is attached to
//const int TB2 = 2; // pin to which TB2 button is conencted
//const int TEST = 3; // pin to which TEST button is conencted
const int Relay1 = 12; //pin to which relay 1 is conencted
const int Relay2 =11; //pin to which relay 2 is conencted
const int Relay3 = 10; //pin to which relay 3 is conencted
const unsigned char temp1=1; //.5 degree*10mV*1024/5V
const unsigned char temp2=47; //23 degree*10mV*1024/5V
const unsigned char temp3=59; //29 degree*10mV*1024/5V
float temperature = 0; //added for serial read
// Variables:
int TempSens1_Reading= 0; // temperature sensor 1 reading
//int TB2buttonState; // the current reading from the input pin
//int TB2lastButtonState = LOW; // the previous reading from the input pin
//long TB2lastDebounceTime = 0; // the last time the output pin was toggled
//int TESTbuttonState; // the current reading from the input pin
//int TESTlastButtonState = LOW; // the previous reading from the input pin
//long TESTlastDebounceTime = 0; // the last time the output pin was toggled
//long debounceDelay = 150; // the debounce time; increase if the output flickers
//int read_TB2(){
//int reading = digitalRead(TB2);
//if (reading != TB2lastButtonState) {
//TB2lastDebounceTime = millis();
//if ((millis() - TB2lastDebounceTime) > debounceDelay) {
//TB2buttonState = reading;
//TB2lastButtonState = reading;
//return TB2buttonState;
//int read_TEST(){
//int reading = digitalRead(TEST);
//if (reading != TESTlastButtonState) {
//TESTlastDebounceTime = millis();
//if ((millis() - TESTlastDebounceTime) > debounceDelay) {
//TESTbuttonState = reading;
//TESTlastButtonState = reading;
//return TESTbuttonState;
// Assign inputs and outputs
//pinMode(TB2 , INPUT); //set TB2 pin an input pin
//pinMode(TEST , INPUT); //set TEST pin an input pin
pinMode(Relay1, OUTPUT); //set Relay1 pin an ouput pin
pinMode(Relay2, OUTPUT); //set Relay1 pin an ouput pin
pinMode(Relay3, OUTPUT); //set Relay1 pin an ouput pin
digitalWrite(Relay1, LOW);
digitalWrite(Relay2, LOW);
digitalWrite(Relay3, LOW);
//while (read_TEST()==true){
//digitalWrite(Relay1, HIGH);
//digitalWrite(Relay2, HIGH);
//digitalWrite(Relay3, HIGH);
//while (read_TEST()==false && read_TB2()==false){
//digitalWrite(Relay1, LOW);
//digitalWrite(Relay2, LOW);
//digitalWrite(Relay3, LOW);
//while (read_TEST()==false && read_TB2()==true){
TempSens1_Reading = analogRead(TempSens1);
if (TempSens1_Reading >=temp1){
if (TempSens1_Reading >=temp2){
if (TempSens1_Reading >=temp3){
if (TempSens1_Reading <=temp3){
if (TempSens1_Reading <=temp2){
if (TempSens1_Reading <=temp1){
