Guys can you help me out on how to enable serial interrupt routine. when i receive a data from the Serial buffer that would be Serial.available() != 0. will go to a function to handle the receive data. and this should be an interrupt routine. the code bellow does not do the job. i just migrated from PIC to arduino so some i'm new to arduino.
thanks
if (Serial.available() > 0)
pcreceivedata(); // if data is receive on the serial buffer check it
if (stopreceive == true)
portswitch();
i = 0;
stopreceive = false;
Rolandchok:
if they will not implement a good interrupt handling this could defeat the purpose of the MCU. its not giving much flexibility like access to SFR.
As AWOL says there is already an interrupt handler. You can replace it if you want to. What is the problem you are really trying to solve?
Maybe, but they've sold a lot of them. It can't have fundamental design flaws like, no interrupt handling.
Looking at your recent posts they are about how you can't do "this" or "that" that you used to do on the PIC.
But how about describing your project? What do you want to do? What are you building? It's like saying "I migrated from Pascal to C and feature X seems to be missing". Well, maybe. But if you concentrate on what you want to achieve I am sure people here will help you achieve it.
my project is using 3 Serial communication. 2 of those are connected to an ultrasonic sensor Which is the Sparkfun MAXSONAR WR1 and the data RX is sent to PC. now the arduino also takes commands from the PC to control switches. what happens is when the arduino start sending the data once i send data from the PC it will not handle the data. put if the two Sonars are off it take care perfectly the RX data. i need to have an interput handling once the serial port connected to PC receive the data it will stop reading of the two max sonar data and handle the receive data.
How is all this wired up?
Is it Mega?
What does your code look like?
BZZZZZT!
Please, don't lecture on interrupts when you're wasting 9 character periods.
Or, given that you've got 'n' serial inputs, 9n character periods.
the delay actually helps a bit. when im sending all the data if dont put the delay it sends me lots of garbage. like data not in correct order. i have to use analog in instead of the serial i guess. =(
What you need to do is add start and end packet markers, then read and store data as fast as possible, after the start marker arrives, stopping when there is no more data or the end marker has arrived.
Only use the data when both the start and end markers have arrived.
Like so:
#define SOP '<'
#define EOP '>'
bool started = false;
bool ended = false;
char inData[80];
byte index;
Serial.begin(57600);
// Other stuff...
// Read all serial data available, as fast as possible
while(Serial.available() > 0)
char inChar = Serial.read();
if(inChar == SOP)
index = 0;
inData[index] = '\0';
started = true;
ended = false;
else if(inChar == EOP)
ended = true;
if(index < 79)
inData[index] = inChar;
index++;
// We are here either because all pending serial
// data has been read OR because an end of
// packet marker arrived. Which is it?
if(started && ended)
// The end of packet marker arrived. Process the packet
// Reset for the next packet
started = false;
ended = false;
index = 0;
the data actually has a header and its 'R' and a stop byte of 0x0D followed by '/n' what i did is look for 'R' and start reading the serial buffer and end reading when the buffer is full. it does the job actually no issues. but the problem arises when i send data coming from the PC it does not carry out the command and you have to send it like 10 times or more to be able to execute the command coming from the PC.
Your code is wrong. It is nothing to do with needing to add interrupt handlers to "put data in a buffer". There are already interrupt handlers for serial and they already do that.
... it does the job actually no issues. but the problem arises ...
It works with no issues, but problems arise, eh? Make up your mind.
Here is one problem:
void pcreceivedata()
if (startrx == 0x24) // check for $ in the serial buffer
do
pcbuffer[0] = 0x24;
tempbuffer = Serial.read();
pcbuffer[i] = tempbuffer;
i++;
delay(10);
}while (tempbuffer != 0x2A);
stopreceive = true;
Your "if available" guarantees you have a single byte. But then you do Serial.read() inside a loop, until you get 0x2A. You then add in a delay to try to give it time to arrive. Read this, restructure to not do it this way:
PaulS was saying the same thing. Listen to him.
... you have to send it like 10 times or more to be able to execute the command coming from the PC.
