Serial issue (blocking and while loop)
I have a sketch that talks to an HTTP web page via a esp8266 module.
Needless to say, this module has almost been more headache that it is worth - and I feel my solution lies in a better WiFi chip or ethernet shield.
Regardless, let's take a look at some code:
#include <EEPROM.h>
#include <SoftwareSerial.h>
//#include <LiquidCrystal.h>
int esp8266_CH_PD = 2;
int esp8266_cmd_timeout = 3000;
String server_response_buffer;
String current_time;
// Config variables in eeprom
char server_ip[15];
char server_port[5];
char server_vhost[50];
char wifi_ssid[50];
char wifi_pass[50];
char input_line[50];
bool input_complete = false;
char input_mode[20];
char tmp_var_1[50];
char tmp_var_2[50];
char tmp_var_3[50];
  get_eeprom_value("server_ip",server_ip);
  get_eeprom_value("server_port",server_port);
  get_eeprom_value("server_vhost",server_vhost);
  get_eeprom_value("wifi_ssid",wifi_ssid);
  get_eeprom_value("wifi_pass",wifi_pass);
  strcpy(input_line,"");
  strcpy(input_mode,"none");
  current_time.reserve(16);
  server_response_buffer.reserve(500);
  unsigned long start = millis();
  String cmd_response;
  cmd_response = "";
  Serial3.begin(9600);
  Serial.println("Booting...");
  pinMode(esp8266_CH_PD, OUTPUT);
  digitalWrite(esp8266_CH_PD, 1);
  Serial.println("First loop");
  while(1) {
    if(Serial3.available()) {
      cmd_response += (char) Serial3.read();
    if(cmd_response.endsWith("[System Ready, Vendor:www.ai-thinker.com]\r\n")) {
      Serial.println("esp8266 seems ready");
    if( (millis()-start) >= 10000) {
      Serial.println("esp8266 is not ready");
  Serial.println("Second loop");
  cmd_response = "";
  Serial3.println("AT+CWMODE=1");
  while(1) {
    if(cmd_response.endsWith("OK\r\n") || cmd_response.endsWith("no change\r\n")) {
      Serial.println("Got ok status from esp8266");
      Serial.println("esp8266 timed out at_cwmode=1");
  Serial.println("Third loop");
  cmd_response = "";
  Serial3.print("AT+CWJAP=\"");
  Serial3.print(wifi_ssid);
  Serial3.print("\",\"");
  Serial3.print(wifi_pass);
  Serial3.print("\"\r\n");
  while(1) {
    if(cmd_response.endsWith("OK\r\n")) {
      Serial.println("esp8266 join AP success");
      Serial.println("esp8266 timed out w/ join ap cmd");
  Serial.println("ITL TimeclockOS is up and running!");
  lcd.setCursor(0,1);
  lcd.print("System ready    ");
  //fetch_data("/");
  //Serial.println(server_response_buffer);
I have left the loop() and a couple other functions out - not that I imagine that make a difference.
Now here is the wonderful part that is pi**ing me off.... When this setup() routine runs, here is what happens at the serial console:
Booting...
First loop
pause for 10 seconds
Second loop
esp8266 timed out at at_cwmode=1
Third loop
Now pay close attention: there is only ONE 10 second pause! Take a look at the code - there should have been a total of THREE 10-second pauses... no? It looks as though the next TWO wile() loops are running in parallel with the first! I can imagine no way possible that the other TWO while() loops execute and hit the 10 second timeouts (in a total of 10 seconds for all 3 loops) unless the other two are running at the same time.
Let me stress that point: A total of 10 seconds is taking place from boot start, to finish.
But this gets even stranger. You see.. when I take a BLANK sketch (without anything in loop() and without my additional 4 custom functions).. the entire block of setup() code works!!!!!!
I cannot imagine how 3 or 4 other defined functions OUTSIDE the setup() function would affect the functionality within the setup() loop itself. Seriously.. what am I missing?
I am soooooooo close to getting a Rasberry Pi and writing some Perl - needless to say, I am NOT a C guy. But the inconsistencies I have faced with this Arduino and C has got me pulling my hair out.
Another point to mention that adds to my frustration: THIS CODE WORKED LAST NIGHT!!!! All I did was power the Arduino down, went to bed and woke back up. NO CODE WAS ALTERED! Yet, it was working (more than several dozen cycles) last night!
Please, somebody...
  • Dean
This code, when executed in my main sketch
char server_ip[15];
...are both too small.
No. But this will help...
  unsigned long start;
  start = millis();  // <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
  while(1) {
  cmd_response = "";
  while(1) {
  while(1) {
Wow....
Amazing how I overlooked that one. Thanks a million!
Found out why the esp8266 was not communicating on my main sketch - but worked on the other....
Had CH_PD int wrong. Finally got it working (again).
Coding Badly:
Thanks for pointing out the size issue on them two variables... forgot the space for null.
deanrantala:
  • and I feel my solution lies in a better WiFi chip or ethernet shield.
Very unlikely if the ESP8266 is used properly
...R
