I have a program that executes properly on an Uno R4 when the board is connected by usb to my computer. When I power it by other means however (I've tried both a 10amp switching power supply as well as a barrel connector adapter) it will not run. Does the R4 automatically load something when the usb is connected? Or is it something in my code or setup? I know it's sloppy right now, still cleaning it up.
#include "EasyNextionLibrary.h" // Include EasyNextionLibrary
#include <SPI.h>
#define SS_M1 11
#define DIR_M1 2
#define PWM_M1 9
#define ENABLE_MOTORS 8
int pwm1;
boolean dir1;
EasyNex myNex(Serial1); // Create an object of EasyNex class with the name < myNex >
// Set as parameter the Hardware Serial you are going to use
myNex.begin(9600); // Begin the object with a baud rate of 9600
unsigned int configWord;
pinMode(SS_M1, OUTPUT); digitalWrite(SS_M1, LOW); // HIGH = not selected
pinMode(DIR_M1, OUTPUT);
pinMode(PWM_M1, OUTPUT); digitalWrite(PWM_M1, LOW);
pinMode(ENABLE_MOTORS, OUTPUT);
digitalWrite(ENABLE_MOTORS, HIGH); // HIGH = disabled
configWord = 0b0000010000001100;
SPI.beginTransaction(SPISettings(14000000, LSBFIRST, SPI_MODE1));
// Motor 1
SPI.transfer(lowByte(configWord));
SPI.transfer(highByte(configWord));
digitalWrite(SS_M1, HIGH);
//Set initial actuator settings to pull at 0 speed for safety
dir1 = 0;
pwm1 = 255;
digitalWrite(ENABLE_MOTORS, LOW);
dir1 = 0;
pwm1 = 127;
digitalWrite(DIR_M1, dir1);
analogWrite(PWM_M1, pwm1);
myNex.NextionListen(); // This function must be called repeatedly to respond to touch events
// from Nextion touch panel.
void trigger5() {
void trigger4() {
float breath = myNex.readNumber("n2.val");
float insp = myNex.readNumber("n0.val");
insp = insp/1000;
float expi = myNex.readNumber("n1.val");
expi = expi/1000;
float tidal = myNex.readNumber("n3.val");
float length = tidal/500;
length = length;//*2.3333;
float timeinsp = length / insp;
timeinsp = timeinsp * 255;
float timeexp = length / expi;
timeexp = timeexp * 255;
uint32_t myintimer = myNex.readNumber("n0.val");
myintimer = myintimer * 1000;
uint32_t myouttimer = myNex.readNumber("n1.val");
myouttimer = myouttimer * 1000;
uint8_t speedin = timeinsp;
uint8_t speedout = timeexp;
uint32_t breathstot = myNex.readNumber("n4.val");
uint32_t breaths = 0;
do {
dir1 = 1;
pwm1 = speedin;
delayMicroseconds(myintimer);
dir1 = 0;
pwm1 = speedout;
delayMicroseconds(myouttimer);
breaths++;
} while (breaths < breathstot);
