Hello
I've encounted a weird problem with Serial. I'm using a Pro clone, and programming it via a FTDI module. All has been fine up till now. But now I have a program that requires the arduino to send a Serial message back to the PC several times a second, and after about 200 times, i.e. after a few seconds, the Serial port becomes unresponsive and the program appears to hang. Then I can't even upload a sketch, not even the bare minimum. Switching USB sockets makes no difference. I get these error messages:
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM3
Using Programmer : arduino
Overriding Baud Rate : 57600
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xe7
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xe7
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xe7
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xe7
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xe7
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xe7
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xe7
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xe7
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xe7
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xe7
avrdude done. Thank you.
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
Nothing I can do will fix it, not even a brand new programming module. Same problem with a different PC. The strangest thing is that if I walk away for half an hour, it usually becomes responsive again, but then the same issue occurs.
I thought that because I had a biggish capacitor across the power supply that could be stopping the arduino from resetting, but I've removed that and the problem is still there.
As I say, I've been uploading and running sketches to this module for weeks without difficulty. What can have happened?
