Hello everybody,
Since a few time I have an issue With My Mega 2560
It is now impossible to upload sketches with the USB port
I had to buy an USBTINYISP which can upload sketches
Blink sketch is working fine on it
But... when I try to print data on the serial monitor Nothing appear.
I tried the loop back test : the leds tx and rx are blinking when I send text to arduino but Nothing is printed on the serial monitor.
Driver seems ok
I tried to burn the bootloader here is what I get :
avrdude: Version 6.0.1, compiled on Apr 15 2015 at 19:59:58
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "F:\ProgramFiles\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : usb
Using Programmer : usbtiny
avrdude: usbdev_open(): Found USBtinyISP, bus:device: bus-0:\.\libusb0-0001--0x1781-0x0c9f
AVR Part : ATmega2560
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PA0
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 10 8 0 no 4096 8 0 9000 9000 0x00 0x00
flash 65 10 256 0 yes 262144 256 1024 4500 4500 0x00 0x00
lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : USBtiny
Description : USBtiny simple USB programmer, USBtinyISP - Inexpensive USB AVR Programmer
avrdude: programmer operation not supported
avrdude: Using SCK period of 10 usec
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e9801
avrdude: NOTE: "flash" memory has been specified, an erase cycle will be performed
To disable this feature, specify the -D option.
avrdude: erasing chip
avrdude: reading input file "C:\Users\ReminGToN\AppData\Roaming\Arduino15\packages\arduino\hardware\avr\1.6.6/bootloaders/stk500v2/stk500boot_v2_mega2560.hex"
avrdude: writing flash (261406 bytes):
Writing | ################################################## | 100% 0.00s
avrdude: 261406 bytes of flash written
avrdude: verifying flash memory against C:\Users\ReminGToN\AppData\Roaming\Arduino15\packages\arduino\hardware\avr\1.6.6/bootloaders/stk500v2/stk500boot_v2_mega2560.hex:
avrdude: load data flash data from input file C:\Users\ReminGToN\AppData\Roaming\Arduino15\packages\arduino\hardware\avr\1.6.6/bootloaders/stk500v2/stk500boot_v2_mega2560.hex:
avrdude: input file C:\Users\ReminGToN\AppData\Roaming\Arduino15\packages\arduino\hardware\avr\1.6.6/bootloaders/stk500v2/stk500boot_v2_mega2560.hex contains 261406 bytes
avrdude: reading on-chip flash data:
avrdude: verifying ...
avrdude: verification error, first mismatch at byte 0x3e000
0xff != 0x0d
avrdude: verification error; content mismatch
avrdude done. Thank you.
Erreur lors de la gravure de la séquence d'initialisation.
I hope that you can help me with this and that my board is not dead...
The serial port still not working
Thank you for reading
