Serial LCD commands
Hi! I've bought an lcd05 serial display and I'm reading right now the datasheet (http://www.robotshop.com/content/PDF/datasheet-lcd05-20-4-green.pdf). I don't understand how to write the set Cursor serial command. Should I write:
Serial.write(0x03, 1,0);
in order to write on the second row? OrI have to write 2 different commands like:
Serial.write(0x03);
Serial.write(1,0);
two ways according to PDF
void LCDSetCUrsor(uint8_t x, uint8_t y)
  Serial.write(0x02);
  Serial.write(x + 16*y);  // 16 should be 20 if your screen is a 20x4  or a 20x2
  Serial.write(0x03);
  Serial.write(x);
  Serial.write(y);
It doesn't work properly. It only erase the first two letters (with LCDSetCUrsor(0,3);). I have Arduino Due, could it be the problem?
the code sets the cursor on a certain position. It does not clear the screen. check the PDF
12 Clear screen Clears the screen and sets cursor to the home position
void LCDClear()
  Serial.write(0x0C);  // 12 decimal
Thank you! Now it works perfectly!
