Serial LCD Error Problem
Helghast-Engineer:
Hello, I'm new here and I hope this is the right place to post this.
I'm using this code I found to try and use my 16x2 serial LCD I bought off of Sparkfun:
#include <SparkSoftLCD.h>
// LCD transmit pin
#define LCD_TX 2
SparkSoftLCD lcd = SparkSoftLCD(LCD_TX);
// setup lcd
pinMode(LCD_TX, OUTPUT);
lcd.begin(9600);
lcd.clear();
// hidden cursor
lcd.cursor(0);
show_setup();
lcd.clear();
      // block-style blinking cursor
    lcd.cursor(2);
    lcd.print("Arming");
    delay(1500);
    lcd.clear();
      // hidden cursor
    lcd.cursor(0);
    lcd.print("16");
    lcd.cursorTo(2,1);
    lcd.print("---------------*");
    for( byte i = 15; i >= 1; i-- ) {
        lcd.scroll(false);
        // as we scroll left, we need to move our cursor to
        // the right to continue to show our countdown
        // in this way, we achieve the sense that a fuse is getting
        // shorter...
        lcd.cursorTo(1,1 + (16 - i) );
        lcd.print(i, DEC);
      // make last bit disappear
    lcd.scroll(false);
    lcd.clear();
    lcd.cursorTo(2, 10);
    lcd.print("(boom)");
    delay(2000);
void show_setup() {
lcd.print("I am setting up!");
// send cursor to 2nd row, first column
lcd.cursorTo(2,1);
for (byte i = 0; i <= 15; i++ ) {
     delay(150);
       // scroll display to the right
     lcd.scroll(true);
delay(1500);
lcd.print("One more moment");
     delay(150);
       // scroll back to the left, revealing our new text
     lcd.scroll(false);
I keep getting the error: "SparkSoft LCD Does not name a type."
Any advice? Thank you!
I believe your problem is with
You should probably do it this way:
SparkSoftLCD lcd(LCD_TX);
or use the new operator after the equals sign assuming the arduino programming environment supports new. I am not sure. If it is standard C++ or even Java then it should.
